mount: /misc: mount point does not exist.
mount: /oem: special device /dev/block/by-name/oem does not exist.
mount: /userdata: special device /dev/block/by-name/userdata does not exist.
Starting logging: OK
Populating /dev using udev: [    2.831203] udevd[139]: starting version 3.2.5
[    2.852572] ==========>>>>>>>>>>>>> ret1 = -1
[    2.883677] udevd[140]: starting eudev-3.2.5
read-only file system detected...done
Will now mount all partitions in /etc/fstab
Note: Will auto format partitons, remove /.auto_mkfs to disable
Note: Create /.skip_fsck to skip fsck
 - The check might take a while if didn't shutdown properly!
Handling /dev/rkflash0p6 / ext2 rw,noauto 1
[    3.353590] ==========>>>>>>>>>>>>> ret1 = -1
Wrong fs type(ext2) for /dev/rkflash0p6
Handling /dev/rkflash0p3 /misc emmc defaults 0
Unsupported file system emmc for /dev/rkflash0p3
Handling /dev/rkflash0p7 /oem squashfs defaults 2
Unsupported file system squashfs for /dev/rkflash0p7
Handling /dev/rkflash0p8 /userdata ext2 defaults 2
Checking /dev/rkflash0p8(ext2)
[    3.854641] ==========>>>>>>>>>>>>> ret1 = -1
e2fsck 1.43.9 (8-Feb-2018)
userdata was not cleanly unmounted, check forced.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
userdata: 138/26768 files (12.3% non-contiguous), 16928/106988 blocks
Mounting /dev/rkflash0p8(ext2) on /userdata
Log saved to /tmp/mountall.log
Starting system message bus: done
[    4.355627] ==========>>>>>>>>>>>>> ret2 = -1
[    4.355700] vendor storage:20160801 ret = -1
Starting network: ip: RTNETLINK answers: File exists
FAIL
Starting dhcpcd...
dev: loaded udev
no interfaces have a carrier
forked to background, child pid 423
Starting watch_ntpd.sh: OK
run ntpd once and watch it every 86400 seconds
Starting sshd:  1 Jan 08:00:04 ntpd[434]: ntpd 4.2.8p10@1.3728-o Thu Nov 24 04:36:35 UTC 2022 (1): Starting
 1 Jan 08:00:04 ntpd[434]: Command line: ntpd -gq
OK
 1 Jan 08:00:04 ntpd[434]: proto: precision = 0.583 usec (-21)
 1 Jan 08:00:04 ntpd[434]: Listen and drop on 0 v6wildcard [::]:123
 1 Jan 08:00:04 ntpd[434]: Listen and drop on 1 v4wildcard 0.0.0.0:123
 1 Jan 08:00:04 ntpd[434]: Listen normally on 2 lo 127.0.0.1:123
 1 Jan 08:00:04 ntpd[434]: Listen normally on 3 lo [::1]:123
 1 Jan 08:00:04 ntpd[434]: bind(20) AF_INET6 fe80::a027:19af:38a3:5fa8%2#123 flags 0x11 failed: Cannot assign requested address
 1 Jan 08:00:04 ntpd[434]: unable to create socket on eth0 (4) for fe80::a027:19af:38a3:5fa8%2#123
 1 Jan 08:00:04 ntpd[434]: failed to init interface for address fe80::a027:19af:38a3:5fa8%2
 1 Jan 08:00:04 ntpd[434]: Listening on routing socket on fd #20 for interface updates
Debug: configfs_init
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/uac1.gs0': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/uac2.gs0': No such file or directory
[    4.933487] file system registered
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/mtp.gs0': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/rndis.gs0': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/acm.gs6': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/mass_storage.0': No such file or directory
mkdir: cannot create directory '/sys/kernel/config/usb_gadget/rockchip/functions/uvc.gs6': No such file or directory
[    5.032915] read descriptors
[    5.032981] read strings
[    6.040581] dwc2 ff400000.usb: bound driver configfs-gadget
load wifi modules: [    6.327755] RTW: module init start
[    6.327803] RTW: rtl8723ds v5.13.5-34-gf315764ad.20220118_COEX20210106-3b3b
[    6.327815] RTW: build time: Nov 24 2022 09:42:10
[    6.327829] RTW: rtl8723ds BT-Coex version = COEX20210106-3b3b
[    6.327839] RTW: ## Calling platform_driver_register
[    6.649869] rk_gmac-dwmac ff4e0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
 1 Jan 08:00:06 ntpd[434]: Listen normally on 5 eth0 [fe80::a027:19af:38a3:5fa8%2]:123
[    7.327654] RTW: rtw_android_wifictrl_func_add: platform_driver_register timeout
[    7.327844] RTW: rtw_inetaddr_notifier_register
[    7.328276] RTW: == SDIO Card Info ==
[    7.328322] RTW:   card: ffffffc0077a4000
[    7.328344] RTW:   clock: 50000000 Hz
[    7.328364] RTW:   timing spec: sd high-speed
[    7.328401] RTW:   sd3_bus_mode: FALSE
[    7.328421] RTW:   func num: 1
[    7.328445] RTW:   func1: ffffffc00778e400 (*)
[    7.328474] RTW: ================
[    7.328497] RTW: CHIP TYPE: RTL8723D
[    7.328678] RTW: loadparam, Select P2P interface: iface_id:1
[    7.329122] RTW: Chip Version Info: CHIP_8723D_T4_1T1R_RomVer(0)
[    7.331837] RTW: SetHwReg: bMacPwrCtrlOn=1
[    7.332339] RTW: sdio_power_on_check: val_mix:0x0002063f, res:0x0002063f
[    7.332367] RTW: sdio_power_on_check: 0x100 the result of cmd52 and cmd53 is the same.
[    7.332486] RTW: sdio_power_on_check: 0x1B8 test Pass.
[    7.333176] RTW: _InitPowerOn_8723DS: Normal Mode
[    7.333251] RTW: _InitPowerOn_8723DS: LDO Mode
[    7.333305] RTW: ReadAdapterInfo8723DS, 0x4e=0x82
[    7.333410] RTW: EEPROM type is E-FUSE
[    7.334390] RTW: hal_EfuseSwitchToBank: Efuse switch bank to 0
[    7.360210] RTW: hal_ReadEFuse_WiFi: data end at address=0xa9
[    7.360275] RTW: HW EFUSE
[    7.360298] RTW: 0x000: 29 81 40 7C  E1 88 07 00  A0 04 EC 35  12 C0 A2 D8
[    7.360374] RTW: 0x010: 28 27 26 26  26 26 2A 2A  2A 29 28 02  FF FF FF FF
[    7.360448] RTW: 0x020: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.360571] RTW: 0x030: FF FF FF FF  FF FF FF FF  FF FF 22 22  22 22 22 22
[    7.360650] RTW: 0x040: 21 21 21 21  21 02 FF FF  FF FF FF FF  FF FF FF FF
[    7.360758] RTW: 0x050: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.360836] RTW: 0x060: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.360913] RTW: 0x070: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.360987] RTW: 0x080: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.361061] RTW: 0x090: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.361139] RTW: 0x0A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.361212] RTW: 0x0B0: FF FF FF FF  FF FF FF FF  20 2A 21 00  00 00 FF FF
[    7.361286] RTW: 0x0C0: FF 29 20 11  00 00 00 FF  00 FF 11 FF  FF FF FF FF
[    7.361361] RTW: 0x0D0: 3E 10 01 12  23 FF FF FF  20 04 4C 02  23 D7 21 02
[    7.361434] RTW: 0x0E0: 0C 00 22 04  00 08 00 32  FF 21 02 0C  00 22 2A 01
[    7.361558] RTW: 0x0F0: 01 00 00 00  00 00 00 00  00 00 00 00  02 00 FF FF
[    7.361651] RTW: 0x100: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
[    7.361739] RTW: 0x110: 00 EB 00 6E  01 00 00 00  00 FF 68 4E  05 9E B4 A3
[    7.361841] RTW: 0x120: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.361917] RTW: 0x130: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.361998] RTW: 0x140: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.362090] RTW: 0x150: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.362183] RTW: 0x160: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.362257] RTW: 0x170: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.362330] RTW: 0x180: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.362408] RTW: 0x190: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.362482] RTW: 0x1A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.362613] RTW: 0x1B0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.362707] RTW: 0x1C0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.362786] RTW: 0x1D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.362863] RTW: 0x1E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.362938] RTW: 0x1F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[    7.363126] RTW: Hal_EfuseParseBTCoexistInfo_8723D: Enable BT-coex, ant_num=1
[    7.363145] RTW: hal_com_config_channel_plan chplan:0x20
[    7.363156] RTW: Hal_EfuseParseVoltage_8723D hwinfo[EEPROM_Voltage_ADDR_8723D] =a0
[    7.363166] RTW: Hal_EfuseParseVoltage_8723D pHalData->adjuseVoltageVal =a
[    7.363439] RTW: kfree Pwr Trim flag:1
[    7.363451] RTW: bb_gain(S1):-2
[    7.363463] RTW: bb_gain(S0):-2
[    7.363817] RTW: rtl8723d_FirmwareDownload fw: FW_NIC, size: 30830
[    7.363840] RTW: rtl8723d_FirmwareDownload: fw_ver=33 fw_subver=0004 sig=0x23d1, Month=12, Date=17, Hour=11, Minute=44
[    7.363851] RTW: rtl8723d_FirmwareDownload(): Shift for fw header!
[    7.363878] RTW: rtl8723d_FirmwareDownload: FW exists before download FW
[    7.364060] RTW: _8051Reset8723: Finish
[    7.364072] RTW: rtl8723d_FirmwareDownload by IO write!
[    7.480708] RTW: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x07070705
[    7.480738] RTW: rtl8723d_FirmwareDownload: download FW count:1
[    7.481043] RTW: _8051Reset8723: Finish
[    7.499465] RTW: _FWFreeToGo: Polling FW ready OK! (291, 18ms), REG_MCUFWDL:0x070707c6
[    7.499491] RTW: rtl8723d_FirmwareDownload success. write_fw:1, 135ms
[    7.499542] RTW:  <=== rtl8723d_FirmwareDownload()
[    7.510873] RTW: hal_read_mac_hidden_rpt OK! (2, 11ms), fwdl:1, id:0x19
[    7.511376] RTW: SetHwReg: bMacPwrCtrlOn=0
[    7.511839] RTW: rtw_hal_read_chip_info in 183 ms
[    7.511886] RTW: [RF_PATH] ver_id.RF_TYPE:RF_1T1R
[    7.511898] RTW: [RF_PATH] HALSPEC's rf_reg_trx_path_bmp:0x11, rf_reg_path_avail_num:1, max_tx_cnt:1
[    7.511908] RTW: [RF_PATH] PG's trx_path_bmp:0x00, max_tx_cnt:0
[    7.511917] RTW: [RF_PATH] Registry's trx_path_bmp:0x00, tx_path_lmt:0, rx_path_lmt:0
[    7.511926] RTW: [RF_PATH] HALDATA's trx_path_bmp:0x11, max_tx_cnt:1
[    7.511935] RTW: [RF_PATH] HALDATA's rf_type:RF_1T1R, NumTotalRFPath:1
[    7.511945] RTW: rtw_hal_rfpath_init trx_path_bmp:0x11(RF_1T1R), NumTotalRFPath:1, max_tx_cnt:1
[    7.511955] RTW: [TRX_Nss] HALSPEC - tx_nss:1, rx_nss:1
[    7.511964] RTW: [TRX_Nss] Registry - tx_nss:0, rx_nss:0
[    7.511972] RTW: [TRX_Nss] HALDATA - tx_nss:1, rx_nss:1
[    7.511982] RTW: rtw_hal_trxnss_init tx_nss:1, rx_nss:1
[    7.511993] RTW: txpath=0x1, rxpath=0x1
[    7.512003] RTW: txpath_1ss:0x1, num:1
[    7.512189] RTW: init_mlme_default_rate_set: support CCK
[    7.512206] RTW: init_mlme_default_rate_set: support OFDM
[    7.513077] RTW: rtw_alloc_macid((nu/etc/init.d/S66load_wifi_modules: line 45: rk_wifi_init: not found
FAIL
/etc/init.d/S66load_wifi_modules: line 45: wl: not found
ll)) if1, mac_addr:ff:ff:ff:ff:ff:ff macid:1
[    7.513112] RTW: rtw_init_pwrctrl_priv: IPS_mode=0, LPS_mode=0, LPS_level=0
[    7.513143] RTW: IQK FW offload:disable
[    7.513158] RTW: Init_ODM_ComInfo_8723d(): Fv=0 Cv=3
[    7.513221] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
[    7.513676] RTW: phy_ConfigBBWithPgParaFile(): No File PHY_REG_PG.txt, Load from HWImg Array!
[    7.513715] RTW: default power by rate loaded
[    7.51Starting dnsmasq: 3730] RTW: phy_txpwr_by_rate_chk_for_path_dup duplicate 2.4G [A] to [B]
[    7.513753] RTW: init_channel_set_from_rtk_priv((null)) ChannelPlan ID:0x20, ch num:13
[    7.514175] RTW: rtw_macaddr_cfg mac addr:68:4e:05:9e:b4:a3
[    7.514308] RTW: bDriverStopped:True, bSurpriseRemoved:False, bup:0, hw_init_completed:0
[    7.514360] RTW: loadparam, Select P2P interface: iface_id:1
[    7.514584] RTW: init_mlme_default_rate_set: support CCK
[    7.514611] RTW: init_mlme_default_rate_set: support OFDM
[    7.515469] RTW: rtw_alloc_macid((null)) if2, mac_addr:ff:ff:ff:ff:ff:ff macid:1
[    7.515574] RTW: rtw_drv_add_vir_if if2 mac_addr : 6a:4e:05:9e:b4:a3
[    7.515619] RTW: rtw_cfg80211_init_wiphy_band:rf_type=0
[    7.515650] RTW: [HT] HAL Support STBC = 0x01
[    7.515682] RTW: rtw_wiphy_alloc(phy0)
[    7.515732] RTW: rtw_wdev_alloc(padapter=ffffff8008a59000)
[    7.515753] RTW: rtw_wdev_alloc(padapter=ffffff8008a72000)
[    7.515770] RTW: rtw_wiphy_register(phy0)
[    7.515780] RTW: Register RTW cfg80211 vendor cmd(0x67) interface
[    7.515995] RTW: rtw_reg_notifier(phy0)
[    7.516015] RTW: initiator:CORE, wiphy_idx:0, type:USER
[    7.516024] RTW: alpha2:00
[    7.516032] RTW: dfs_region:UNSET
[    7.516040] RTW: intersect:0
[    7.516048] RTW: processed:0
[    7.516056] RTW: country_ie_env:ANY
[    7.516440] RTW: rtw_ndev_init(wlan0) if1 mac_addr=68:4e:05:9e:b4:a3
[    7.517037] RTW: rtw_ndev_notifier_call(wlan0) state:16
[    7.518226] RTW: rtw_ndev_notifier_call(wlan0) state:5
[    7.518416] RTW: rtw_ndev_init(p2p0) if2 mac_addr=6a:4e:05:9e:b4:a3
[    7.519008] RTW: rtw_ndev_notifier_call(p2p0) state:16
[    7.520216] RTW: rtw_ndev_notifier_call(p2p0) state:5
[    7.521717] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
[    7.521788] RTW: module init ret=0
[    7.563255] RTW: rtw_ndev_notifier_call(wlan0) state:13
[    7.OK
563312] RTW: _netdev_open(wlan0) , bup=0
[    7.563403] RTW: FW does not exist before power on!!
[    7.563912] RTW: CardEnable: LP-LPS: 02
[    7.568278] RTW: SetHwReg: bMacPwrCtrlOn=1
[    7.568706] RTW: sdio_power_on_check: val_mix:0x0000063f, res:0x0000063f
[    7.568734] RTW: sdio_power_on_check: 0x100 the result of cmd52 and cmd53 is the same.
[    7.568807] RTW: sdio_power_on_check: 0x1B8 test Pass.
[    7.569100] RTW: _InitPowerOn_8723DS: Normal Mode
[    7.569156] RTW: _InitPowerOn_8723DS: LDO Mode
[    7.569389] RTW: Power on ok!
[    7.569605] RTW: rtl8723d_FirmwareDownload fw: FW_NIC, size: 30830
[    7.569634] RTW: rtl8723d_FirmwareDownload: fw_ver=33 fw_subver=0004 sig=0x23d1, Month=12, Date=17, Hour=11, Minute=44
[    7.569645] RTW: rtl8723d_FirmwareDownload(): Shift for fw header!
[    7.569676] RTW: rtl8723d_FirmwareDownload by IO write!
WAKE_LOCK[open_file_descriptors] fatal error opening "/sys/power/wake_lock": No such file or directory
==========EQ/DRC process release version 1.23===============
snd_pcm_open
snd_pcm_hw_params_malloc
snd_pcm_hw_params_any!
snd_pcm_hw_params_set_access!
snd_pcm_hw_params_set_format
channels = 2
bufferSize = 20480
periodSize = 1024
Rate = 48000
Open record device done
Open PCM: fake_play
[    7.686258] ========>>>>>>>>>>>>>>>> spk_ctl_gpio
[    7.693066] RTW: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x07070705
[    7.693103] RTW: rtl8723d_FirmwareDownload: download FW count:1
[    7.693403] RTW: _8051Reset8723: Finish
interleaved mode
snd_pcm_hw_params_alloca
interleaved mode
format successed
channels = 2
setting sampling rate (48000)
write_bufferSize = 4096
write_periodSize = 1024
rk eq_drc v2.02 2019-07-20 Oct 11 2019 09:26:56
psEqualizer->m_pfControlValue = 0.000000
open write device is successful
WAKE_LOCK[RK_acquire_wake_lock] id=eq_drc_process
[    7.711841] RTW: _FWFreeToGo: Polling FW ready OK! (282, 19ms), REG_MCUFWDL:0x070707c6
[    7.711875] RTW: rtl8723d_FirmwareDownload success. write_fw:1, 142ms
[    7.711909] RTW:  <=== rtl8723d_FirmwareDownload()
[    7.711925] RTW: HalDetectPwrDownMode(): PDN=0
[    7.711934] RTW: Set RF Chip ID to RF_6052 and RF type to 0.
param_name = /data/cfg/eq_bin/Para_48000Hz_2ch.bin
EQ/DRC Algorithm 3BAND_IIR_DIVFREQ PEAK VALUE V1.0...Oct 11 2019 09:26:56
GetLMTVersion v1.03 2019-10-10 Oct 11 2019 09:26:57,force=0 firstInit=1
[    7.777883] RTW: LCK cnt=0
[    7.839038] RTW: rtw_hal_set_macaddr_port wlan0- hw port(0) mac_addr =68:4e:05:9e:b4:a3
[    7.839185] RTW: rtw_hal_set_macaddr_port p2p0- hw port(1) mac_addr =6a:4e:05:9e:b4:a3
[    7.839405] RTW: [HW_VAR_ENABLE_RX_BAR] 0x6A2=0x500
[    7.841384] RTW: rtw_hal_set_macaddr_port wlan0- hw port(0) mac_addr =68:4e:05:9e:b4:a3
[    7.841667] RTW: #### hw_var_set_opmode() -4451 hw_port(0) mode = 2 ####
[    7.841801] RTW: rtw_rf_get_kfree_tx_gain_offset path:S1, ch:6, bb_gain_sel:0, kfree_offset:-2
[    7.842085] RTW: kfree gain_offset 0x55:0x82010 RTW:  after :0x12010
[    7.842675] RTW: rtw_rf_get_kfree_tx_gain_offset path:S0, ch:6, bb_gain_sel:0, kfree_offset:-2
[    7.842956] RTW: kfree gain_offset 0x65:0x82000 RTW:  after :0x12000
[    7.843564] RTW: MAC Address = 68:4e:05:9e:b4:a3
[    7.843579] RTW: rtw_start_drv_threads(wlan0) enter
[    7.843587] RTW: rtw_start_drv_threads(wlan0) start RTW_XMIT_THREAD
[    7.843751] RTW: rtw_start_drv_threads(wlan0) start RTW_RECV_THREAD
[    7.843833] RTW: rtw_start_drv_threads(wlan0) start RTW_CMD_THREAD
[    7.843850] RTW: rtw_recv_thread(wlan0) enter
[    7.843915] RTW: rtl8723d_start_thread(wlan0) start RTWHALXT
[    7.843982] RTW: start rtl8723ds_xmit_thread(wlan0)
[    7.844194] RTW: _netdev_vir_if_open(p2p0) , bup=0
[    7.844210] RTW: rtw_start_drv_threads(p2p0) enter
[    7.844220] RTW: rtl8723d_start_thread(p2p0) start RTWHALXT
[    7.844288] RTW: _netdev_vir_if_open(p2p0) (bup=1) exit
[    7.844290] RTW: start rtl8723ds_xmit_thread(p2p0)
[    7.844308] RTW: -871x_drv - drv_open, bup=1
[    7.844416] RTW: cfg80211_rtw_set_power_mgmt(wlan0) enabled:1, timeout:-1
[    7.844450] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    7.844463] RTW: rtw_ndev_notifier_call(wlan0) state:1
[    7.846085] RTW: cfg80211_rtw_get_txpower(p2p0) total max: -10000 mbm
[    7.883575] RTW: rtw_ndev_notifier_call(p2p0) state:13
[    7.883622] RTW: _netdev_vir_if_open(p2p0) , bup=1
[    7.883636] RTW: _netdev_vir_if_open(p2p0) (bup=1) exit
[    7.883752] RTW: cfg80211_rtw_set_power_mgmt(p2p0) enabled:1, timeout:-1
[    7.883777] IPv6: ADDRCONF(NETDEV_UP): p2p0: link is not ready
[    7.883789] RTW: rtw_ndev_notifier_call(p2p0) state:1
Starting input-event-daemon: input-event-daemon: Start listening on 3 devices...
#  1 Jan 08:00:09 ntpd[434]: Listen normally on 6 eth0 192.168.0.10:123
Stopping dhcpcd...
stopped /sbin/dhcpcd (pid 423)
# cd /data/
# ./start_app.sh
************** start   app *********************
route: SIOCADDRT: File exists
[   23.395271] exe (543): drop_caches: 3
# [   24.313879] sh (547): drop_caches: 3
[DBG]1970-01-01 08:00:24|file_util.c|util_read_struct(494): util_read_struct Num:  0 read size: 0 DataSize: 473 DataMaxNum: 1
/data/nand-1/SYSCONFIG//SYSPARAM.BIN, 473[DBG]1970-01-01 08:00:24|file_util.c|util_read_struct(518): util_read_struct Num:  1 read size: 473 DataSize: 473 DataMaxNum: 1
[DBG]1970-01-01 08:00:24|sys_util.c|util_oper_syscmd(136): cmd[cp -rf /data/nand-1/SYSCONFIG//SYSPARAM.BIN /data/nand-1/SYSCONFIG//SYSPARAM.BIN.BAK ]
[DBG]1970-01-01 08:00:24|file_util.c|util_read_struct(494): util_read_struct Num:  0 read size: 0 DataSize: 478 DataMaxNum: 1
/data/nand-1/SYSCONFIG//USERPARAM.BIN, 478[DBG]1970-01-01 08:00:24|file_util.c|util_read_struct(518): util_read_struct Num:  1 read size: 478 DataSize: 478 DataMaxNum: 1
[DBG]1970-01-01 08:00:24|sys_util.c|util_oper_syscmd(136): cmd[cp -rf /data/nand-1/SYSCONFIG//USERPARAM.BIN /data/nand-1/SYSCONFIG//USERPARAM.BIN.BAK ]
[DBG]1970-01-01 08:00:24|file_util.c|util_read_struct(494): util_read_struct Num:  0 read size: 0 DataSize: 16 DataMaxNum: 10
[DBG]1970-01-01 08:00:24|file_util.c|util_read_struct(518): util_read_struct Num:  0 read size: 0 DataSize: 16 DataMaxNum: 10
[DBG]1970-01-01 08:00:24|file_util.c|util_read_struct(494): util_read_struct Num:  0 read size: 0 DataSize: 11 DataMaxNum: 10
[DBG]1970-01-01 08:00:24|file_util.c|util_read_struct(518): util_read_struct Num:  0 read size: 0 DataSize: 11 DataMaxNum: 10
[DBG]1970-01-01 08:00:24|file_util.c|util_read_struct(494): util_read_struct Num:  0 read size: 0 DataSize: 136 DataMaxNum: 1
/data/nand-2/JD//TUYA_JD//TUYA_ROOMPARAM.BIN, 136[DBG]1970-01-01 08:00:24|file_util.c|util_read_struct(518): util_read_struct Num:  1 read size: 136 DataSize: 136 DataMaxNum: 1
[DBG]1970-01-01 08:00:24|file_util.c|util_read_struct(494): util_read_struct Num:  0 read size: 0 DataSize: 101 DataMaxNum: 10
/data/nand-2/JD//TUYA_JD//TUYA_AF_DEV_LIST.BIN, 0[DBG]1970-01-01 08:00:24|file_util.c|util_read_struct(518): util_read_struct Num:  0 read size: 0 DataSize: 101 DataMaxNum: 10
[DBG]1970-01-01 08:00:24|storage_wireless_alarm.c|storage_wirelessAf_init(167): storage_wirelessAf_init success
read len = 12
36 47 34 4e 30 30 36 35 32 36 32 54
vendor read string:6G4N0065262T.
read len = 6
00 00 11 22 33 47
vendor read string:.
read len = 16
37 33 38 39 65 38 39 66 33 37 62 30 61 38 35 61
vendor read string:7389e89f37b0a85a.
read len = 32
4d 4b 6d 7a 53 6e 7a 75 43 32 41 32 54 31 38 4a 63 6e 4c 47 36 47 48 51 64 41 76 4d 75 5a 55 69
vendor read string:MKmzSnzuC2A2T18JcnLG6GHQdAvMuZUi.
[DBG]1970-01-01 08:00:24|storage_read_write_id.c|init_storage_sys_config_param(237): sn[6G4N0065262T]; uuid[7389e89f37b0a85a]; key[MKmzSnzuC2A2T18JcnLG6GHQdAvMuZUi]
[DBG]1970-01-01 08:00:24|storage_read_write_id.c|init_storage_sys_config_param(239): mac[00-00-11-22-33-47]
[DBG]1970-01-01 08:00:24|file_util.c|util_write_struct(456): Write Size  473
[DBG]1970-01-01 08:00:24|logic_net_param.c|net_set_ipaddr(256):  MAC:ifconfig eth0 hw ether 00:00:11:22:33:47
[WRN]1970-01-01 08:00:24|logic_net_param.c|UlongtoIP(119): strIp: 192.168.8.175
[DBG]1970-01-01 08:00:24|logic_net_param.c|net_set_ipaddr(272):  IP:ifconfig eth0 192.168.8.175
[   24.585271] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[WRN]1970-01-01 08:00:24|logic_net_param.c|UlongtoIP(119): strIp: 255.255.255.0
[DBG]1970-01-01 08:00:24|logic_net_param.c|net_set_ipaddr(278):  NETMASK:ifconfig eth0 netmask 255.255.255.0
[WRN]1970-01-01 08:00:24|logic_net_param.c|UlongtoIP(119): strIp: 192.168.8.254
[DBG]1970-01-01 08:00:24|logic_net_param.c|net_set_ipaddr(286):  GW:route add default gw  192.168.8.254 metric 1
[DBG]1970-01-01 08:00:24|logic_wifi_set.c|st_init_wifi_thread(909): g_WifiNetParam->EnableWifi:1
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_register(1582): ms_media_register for [MsRtpRecvVideo] [2]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_register(1582): ms_media_register for [MsRtpSendAudio] [1]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_register(1582): ms_media_register for [MsRtpRecvAudio] [2]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_queue_init(94): input number == 0 name == MsH264Dec
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_register(1582): ms_media_register for [MsH264Dec] [0]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_register(1582): ms_media_register for [MsVideoPreview] [1]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_queue_init(94): input number == 1 name == MsAlawDec
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_register(1582): ms_media_register for [MsAlawDec] [0]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_register(1582): ms_media_register for [MsAlawEncSw] [1]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_register(1582): ms_media_register for [MsAudioAi] [2]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_register(1582): ms_media_register for [MsPCMaO] [1]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_register(1582): ms_media_register for [MsJpegDec] [2]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_register(1582): ms_media_register for [MsJpegEnc] [2]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_register(1582): ms_media_register for [MsMp3Play] [2]
[DBG]1970-01-01 08:00:24|logic_wav_play.c|ms_wav_play_init(600): ms_wav_play_init  f->mcount=0
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_register(1582): ms_media_register for [MsAudioPlay] [2]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_queue_init(94): input number == 0 name == MsWavRecord
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_register(1582): ms_media_register for [MsWavRecord] [0]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_register(1582): ms_media_register for [MsLylyPlay] [2]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_queue_init(94): input number == 2 name == MsAviRecord
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_register(1582): ms_media_register for [MsAviRecord] [0]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_register(1582): ms_media_register for [MsRtspPlay] [2]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_register(1582): ms_media_register for [MSFileLYLY] [2]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_register(1582): ms_media_register for [MsUrlPlay] [2]
[WRN]1970-01-01 08:00:24|au_audio_input.c|audio_record_set_analog_gain(465):  Avoid affecting the ASR effect, do not change !!!
[DBG]1970-01-01 08:00:24|au_audio_output.c|audio_play_set_analog_gain(269): MONI GAIN: 3
[DBG]1970-01-01 08:00:24|sys_util.c|util_oper_syscmd(136): cmd[amixer cset name='DAC LINEOUT Left Volume' 3]
[ERR]1970-01-01 08:00:24|logic_wifi_set.c|st_wpa_supplicant_init(503): enable sta failed!
[   24.833966] RTW: rtw_ndev_notifier_call(wlan0) state:9
[   24.834067] RTW: netdev_close(wlan0) , bup=1
[   24.834089] RTW: (2)871x_drv - drv_close, bup=1, hw_init_completed=_TRUE
[   24.834434] RTW: rtw_hal_set_bssid wlan0- hw port -0 BSSID: 00:00:00:00:00:00
[   24.834607] RTW: rtw_set_rts_bw connect_to_8812=0,enable=1
[   24.834897] RTW: rtw_cfg80211_indicate_disconnect(wlan0) ,reason = 0
[   24.834922] RTW: rtw_cfg80211_indicate_disconnect(wlan0) call cfg80211_disconnected, reason:0
[   24.835126] RTW: rtw_reset_securitypriv(wlan0) - End to Disconnect
[   24.835349] RTW: rtw_free_assoc_resources-wlan0 tnumid=33,iface=MIXER,name='DAgC LINEOUT Left Volume'
t_networ  ; type=INTEGER,access=rw--k -R--,values=1,min=0,max=3,steMp=0
  : values=3
acAddress=00  | dBscale-min=-6.00dB,step=1.50:00:dB,mute=0
00:00:00:00 ssid=
[   24.835380] RTW: ERROR Free disconnecting network of scanned_queue failed due to pwlan == NULL
[   24.835380]
[   24.835418] RTW: -871x_drv - drv_close, bup=1
[   24.835672] RTW: rtw_ndev_notifier_call(wlan0) state:2
[   24.836[DBG]1970-01-01 08:00:24|sys_util.c|util_oper_syscmd(136): 0cmd[amixer cset name='DAC LINEOUT Right Volume' 3]
83] RTW: cfg80211_rtw_del_key(wlan0) key_index=0, addr=          (null)
[   24.836120] RTW: cfg80211_rtw_del_key(wlan0) key_index=1, addr=          (null)
[   24.836134] RTW: cfg80211_rtw_del_key(wlan0) key_index=2, addr=          (null)
[   24.836148] RTW: cfg80211_rtw_del_key(wlan0) key_index=3, addr=          (null)
[   24.836162] RTW: cfg80211_rtw_del_key(wlan0) key_index=4, addr=          (null)
[   24.836174] RTW: cfg80211_rtw_del_key(wlan0) key_index=5, addr=          (null)
[   24.846986] RTW: rtw_ndev_notifier_call(wlan0) state:13
[   24.847033] RTW: _netdev_open(wlan0) , bup=1
[   24.847112] RTW: -871x_drv - drv_open, bup=1
[   24.847221] RTW: cfg80211_rtw_set_power_mgmt(wlan0) enabled:1, timeout:-1
[   24.847258] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   24.847274] RTW: rtw_ndev_notifier_call(wlan0) state:1
numid=34,iface=MIXER,name='DAC LINEOUT Right Volume'
  ; type=INTEGER,access=rw---R--,values=1,min=0,max=3,step=0
  : values=3
  | dBscale-min=-6.00dB,step=1.50dB,mute=0
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_new(929):  [MsAudioAi]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_new(929):  [MsPCMaO]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_new(929):  [MsAlawDec]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_new(929):  [MsAlawEncSw]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_new(929):  [MsRtpSendAudio]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_new(929):  [MsRtpRecvAudio]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_new(929):  [MsWavRecord]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_new(929):  [MsAudioPlay]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_new(929):  [MsH264Dec]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_new(929):  [MsRtpRecvVideo]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_new(929):  [MsVideoPreview]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_new(929):  [MsJpegDec]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_new(929):  [MsJpegEnc]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_new(929):  [MsLylyPlay]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_new(929):  [MsMp3Play]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_new(929):  [MsAviRecord]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_new(929):  [MSFileLYLY]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_new(929):  [MsRtspPlay]
[DBG]1970-01-01 08:00:24|logic_media_core.c|ms_media_new(929):  [MsUrlPlay]
killall: udhcpc: no process killed
[DBG]1970-01-01 08:00:24|logic_udp_comm.c|create_cmd_socket(126): get socket : 4
[WRN]1970-01-01 08:00:24|logic_udp_comm.c|SockBindDevice(69):  SO_BINDTODEVICE [eth0] SUCCESS !!!
[DBG]1970-01-01 08:00:24|logic_udp_comm.c|recive_cmd_data_proc(451): ***************** recv packet len : 12 *******************
[DBG]1970-01-01 08:00:24|logic_udp_comm.c|check_MainNethead(298): U32Encrypt : 00000000
[DBG]1970-01-01 08:00:24|logic_udp_comm.c|check_MainNethead(299): subProtocolEncrypt : 00
[DBG]1970-01-01 08:00:24|logic_udp_comm.c|net_send_cmd_packet(846): net_send_cmd_packet : size:  12
[WRN]1970-01-01 08:00:24|logic_udp_comm.c|check_packet(358): size[12] err!
[DBG]1970-01-01 08:00:24|file_util.c|util_read_struct(494): util_read_struct Num:  0 read size: 0 DataSize: 40 DataMaxNum: 5
[DBG]1970-01-01 08:00:24|file_util.c|util_read_struct(518): util_read_struct Num:  0 read size: 0 DataSize: 40 DataMaxNum: 5
[DBG]1970-01-01 08:00:24|file_util.c|util_read_struct(494): util_read_struct Num:  0 read size: 0 DataSize: 9 DataMaxNum: 5
[DBG]1970-01-01 08:00:24|file_util.c|util_read_struct(518): util_read_struct Num:  0 read size: 0 DataSize: 9 DataMaxNum: 5
[DBG]1970-01-01 08:00:24|file_util.c|util_read_struct(494): util_read_struct Num:  0 read size: 0 DataSize: 48 DataMaxNum: 20
/data/nand-2/RECORD//MISS.BIN, 960[DBG]1970-01-01 08:00:24|file_util.c|util_read_struct(518): util_read_struct Num:  20 read size: 960 DataSize: 48 DataMaxNum: 20
[DBG]1970-01-01 08:00:24|logic_sys_arbitration.c|sys_init_hint_state(1531): sys_init_hint_state open or close lcd!
[DBG]1970-01-01 08:00:24|logic_sys_arbitration.c|sys_set_hint_state(1339): sys_set_hint_state : HintType:6, flg:1
killall: wpa_supplicant: no process killed
[DBG]1970-01-01 08:00:25|hw_ioctrl_api.c|st_lcd_brightness_set(395): cmd[echo 140 > /sys/devices/platform/backlight/backlight/backlight/brightness]
[WRN]1970-01-01 08:00:25|hw_ioctrl_api.c|hw_spk_amp_on(536): hw_spk_amp_on
[WRN]1970-01-01 08:00:25|hw_ioctrl_api.c|hw_speak_off(597): hw_speak_off
[DBG]1970-01-01 08:00:25|logic_sys_scene.c|st_sys_thread_proc(604): =========== st_sys_state_proc =========
[DBG]1970-01-01 08:00:25|logic_time.c|init_reboot_timer(155): init_reboot_timer  timerdiff : 3437
[DBG]1970-01-01 08:00:25|file_util.c|util_read_struct(494): util_read_struct Num:  0 read size: 0 DataSize: 40 DataMaxNum: 5
reboot time : 02:57:17
[DBG]1970-01-01 08:00:25|file_util.c|util_read_struct(518): util_read_struct Num:  0 read size: 0 DataSize: 40 DataMaxNum: 5
[DBG]1970-01-01 08:00:25|file_util.c|util_read_struct(494): util_read_struct Num:  0 read size: 0 DataSize: 32 DataMaxNum: 10
[DBG]1970-01-01 08:00:25|file_util.c|util_read_struct(518): util_read_struct Num:  0 read size: 0 DataSize: 32 DataMaxNum: 10
[WRN]1970-01-01 08:00:25|hw_ioctrl_api.c|hw_spk_amp_off(557): hw_spk_amp_off
[DBG]1970-01-01 08:00:25|sys_util.c|util_oper_syscmd(136): cmd[aplay -Dplug:softvol /oem/re[DBG]1970-01-01 08:00:25|file_util.c|util_read_struct(494): util_read_struct Num:  0 read size: 0 DataSize: 8 DataMaxNum: 99
[DBG]1970-01-01 08:00:25|file_util.c|util_read_struct(518): util_read_struct Num:  0 read size: 0 DataSize: 8 DataMaxNum: 99
[DBG]1970-01-01 08:00:25|logic_interphone.c|init_list_address(1060):  storage_get_monitorlist return 0
[DBG]1970-01-01 08:00:25|logic_asr.c|st_asr_init(869): deviceName[00:00:11:22:33:47]
read len = 12
36 raw_api_init
read len = 6
00 00 11 22 33 47
[DBG]1970-01-01 08:00:25|logic_net_setup.c|setup_network_deal(881): open setup_network thread
[DBG]1970-01-01 08:00:25|asr_export_api.c|st_asr_dui_init(1813): sspeConfPath[/oem/res/asr_res//sspe.conf]
read len = 16
37 33 38 [DBG]1970-01-01 08:00:25|logic_net_setup.c|HexstrToInt(673): ------HexToInt: hexStr[000011223347] long[287454023]
[DBG]1970-01-01 08:00:25|logic_net_setup.c|st_set_broadcast_delay(720): =====set_register_delay: register delay time [12].
read len = 32
[DBG]1970-01-01 08:00:25|logic_net_setup.c|_raw_report_devinfo(904): The MAC code has been set
 pthread_create ok.
[DBG]1970-01-01 08:00:25|file_util.c|util_read_struct(494): util_read_struct Num:  0 read size: 0 DataSize: 250 DataMaxNum: 10
[DBG]1970-01-01 08:00:25|asr_export_api.c|st_asr_dui_init(1814): authConfPath[/oem/res/asr_res//dui_auth.conf]
[DBG]1970-01-01 08:00:25|st_duilite_common.c|st_dui_conf(181): read from file: json[{
	"productId": "279613643",
	"aliasKey": "test",
	"savedProfileDir": "/data/nand-1/ASR/",
	"savedProfile": "/data/nand-1/ASR/dui.lic",
	"productKey": "8c1165eeec8d32dfdce2f3a9855e401b",
	"productSecret": "64c7f7a26b1816a4d4693848f0007bcb",
	"devInfo": {
		"deviceName": "00:11:22:33:44:F1",
		"platform": "Linux",
		"deviceId":"default",
		"clientName": "HardVer",
		"instructionSet": "SoftVer",
		"chipModel": "rk3308"
	"prof": {
		"enable": 1,
		"level": 3,
		"output": "/data/asr_dui.log"
	"cachePath": "/tmp"
[DBG]1970-01-01 08:00:25|file_util.c|util_read_struct(518): util_read_struct Num:  0 read size: 0 DataSize: 250 DataMaxNum: 10
[DBG]1970-01-01 08:00:25|st_duilite_common.c|st_creat_conf_path(78): dir[/data/nand-1/ASR/]
[DBG]1970-01-01 08:00:25|storage_regularly.c|st_get_regularly_list_from_flash(191): g_pRegularlyList->Count:0
[DBG]1970-01-01 08:00:25|st_duilite_common.c|st_dui_conf(208): enter deal key_devInfo[devInfo]
[DBG]1970-01-01 08:00:25|st_duilite_common.c|st_dui_conf(235): outPutDevInfoStr[{
	"aliasKey":	"test",
	"devInfo":	{
		"deviceName":	"00:00:11:22:33:47",
		"deviceId":	"ZKA1MVG18-100101-REL",
		"clientName":	"V1.01.0001_11:51:14_Mar 17 2023",
	"prof":	{
		"enable":	1,
		"level":	3,
	"cachePath":	"/tmp"
[DBG]1970-01-01 08:00:25|storage_regularly.c|storage_regularly_list_init(260): storage_regularly_list_init success
[DBG]1970-01-01 08:00:25|logic_regularly_remind.c|logic_regularly_event_init(710): pthread_create st_face_download_init start
[DBG]1970-01-01 08:00:25|logic_regularly_remind.c|logic_regularly_event_list_init(668): pList->Count:0
[DBG]1970-01-01 08:00:25|logic_regularly_remind.c|logic_regularly_event_init(728): pthread_create logic_regularly_event_init end 1
[DBG]1970-01-01 08:00:25|logic_regularly_remind.c|st_regularly_deal_proc(468): st_regularly_deal_proc
[DBG]1970-01-01 08:00:25|weather_api.c|weather_api_request(698): pthread_create create success
[WRN]1970-01-01 08:00:25|ui_logic_interface.c|logic_controlFunc(136): call cmd 1 cost 962469us
[INF]1970-01-01 08:00:25|weather_api.c|st_pthread_proc(601): weather pthread start running
[DBG]1970-01-01 08:00:25|main.c|st_dist_common_deal(188): ret[1]
Playing WAVE '/oem/res/ring/Hit/mute.WAV' : Signed 16 bit Little Endian, Rate 16000 Hz, Mono
home control 3.4.2 build Jan 13 2023 15:27:59 start
config:
	"pid":	"myrb6crwfekz9axp",
	"uuid":	"7389e89f37b0a85a",
	"authkey":	"MKmzSnzuC2A2T18JcnLG6GHQdAvMuZUi",
	"storage_path":	"/data/nand-1/TUYACONFIG/",
	"sw_ver":	"10.1.5",
	"log_level":	4,
	"tuya":	{
		"zigbee":	{
			"cache_path":	"/tmp/",
			"dev_name":	"/dev/ttyS0",
			"cts":	1,
			"thread_mode":	1,
			"sw_ver":	"1.0.8"
		"center_ctrl":	{
			"img_path":	"/tmp/",
			"img_size":	{
				"width":	0,
				"height":	0
		"fake":	{
	"user":	[{
			"tp":	10
drm: Found plane_id: 58 connector_id: 62 crtc_id: 60
drm: 480x480 (217mm X 136mm) pixel format AR24
+++++++hc_proc start
DRM subsystem and buffer mapped successfully
[00546:00598]1970-01-01 08:00:25.391 src/auth.c#254  auth version: 0.2.109, dds version: DDS 0.2.109
[00546:00598]1970-01-01 08:00:25.391 src/auth.c#255  auth cfg: {
	"aliasKey":	"test",
	"devInfo":	{
	"prof":	{
		"enable":	1,
		"level":	3,
	"cachePath":	"/tmp"
[00546:00610]1970-01-01 08:00:25.397 src/dds.c#7236  dds dns start
[00546:00610]1970-01-01 08:00:25.397 src/dds_dns.c#731  DNS server start: 0.0.5
[00546:00609]1970-01-01 08:00:25.398 src/dds.c#6818  productId: 279613643
[00546:00610]1970-01-01 08:00:25.399 src/dds_dns.c#748  DNS server udp://127.0.0.1:5353, 0x7f78000fb0
[00546:00609]1970-01-01 08:00:25.399 src/dds.c#6885
dds mode: 0008
server: NULL
loginServer: https://auth.dui.ai/auth/device/login
resServer: https://res.download.dui.ai/res/v1/product/info?productId=
registerServer: https://auth.dui.ai
ttsServer: https://tts.duiopen.com/runtime/v2/synthesize
cinfoServer: https://dds.dui.ai/cinfo/v1
lasrRTServer: wss://lasr.duiopen.com/live/ws2
lasrFLServer: https://lasr.duiopen.com/lasr-file-api/v2
ttsVoiceCopyServer: wss://tts.duiopen.com/api/v1/voicecopy/multiple
ttsVoiceIdCheckServer: https://tts.duiopen.com/api/v1/voicecopy/task/training/progress
[00546:00609]1970-01-01 08:00:25.408 src/dds.c#6952  devInfo value:{
[00546:00609]1970-01-01 08:00:25.410 src/dds.c#6960  devInfo's deviceName: 00:00:11:22:33:47
[00546:00609]1970-01-01 08:00:25.425 src/dds.c#6061  deviceName: 00:00:11:22:33:47
[00546:00609]1970-01-01 08:00:25.426 src/auth.c#55
[00546:00609]1970-01-01 08:00:25.426 src/auth.c#103  deviceName: 00:00:11:22:33:47
[00546:00609]1970-01-01 08:00:25.427 src/dds.c#6207  login url: https://auth.dui.ai/auth/device/login?productId=279613643&deviceName=00:00:11:22:33:47&nonce=6280523&sig=9cea64c239a9d40aea5251f24d936508325c411b
[00546:00609]1970-01-01 08:00:25.428 src/dds.c#6287  dds_do_login post_body:{
	"profile":	"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",
	"info":	{
		"chipModel":	"rk3308",
		"sdkInfo":	"DDS 0.2.109",
		"platform":	"linux"
[01-01 18:12:15 TUYA D][tuya_ws_db.c:450] init fs. Path: /data/nand-1/TUYACONFIG/
[00546:00609]1970-01-01 08:00:25.439 third/mongoose/mongoose.c#12553  dns server: udp://127.0.0.1:5353
[01-01 18:12:15 TUYA I][kv_storge.c:45] Init Kvs With File:/data/nand-1/TUYACONFIG/
[00546:00609]1970-01-01 08:00:25.440 src/dds.c#2724  dds status: idle
[01-01 18:12:15 TUYA D][simplekv.c:945] path:/data/nand-1/TUYACONFIG/
[00546:00609]1970-01-01 08:00:25.441 third/mongoose/mongoose.c#12450  dns server: 127.0.0.1
[00546:00610]1970-01-01 08:00:25.442 src/dds_dns.c#626  DNS query new 0x7f78001090
[00546:00610]1970-01-01 08:00:25.443 src/dds_dns.c#636  DNS query recv from 0x7f78001090
[00546:00610]1970-01-01 08:00:25.443 src/dds_dns.c#664  DNS query type 1 name auth.dui.ai
[00546:00610]1970-01-01 08:00:25.444 third/mongoose/mongoose.c#12553  dns server: udp://114.114.114.114:53
[00546:00610]1970-01-01 08:00:25.445 src/dds_dns.c#561  DNS client udp new 0x7f78002270, 114.114.114.114 start, rname:auth.dui.ai
[01-01 18:12:15 TUYA D][simplekv.c:981] get encrypt_key[??US???kR?
[00546:00610]1970-01-01 08:00:25.446 third/mongoose/mongoose.c#12553  dns server: udp://223.5.5.5:53
[01-01 18:12:15 TUYA D][simplekv.c:1012] both file exist
[00546:00598]1970-01-01 08:00:25.447 src/auth.c#338  dds_auth_do exit
[01-01 18:12:15 TUYA D][simplekv.c:310] size in: 0 and final: 28700 And mag_rec_max: 512
[00546:00610]1970-01-01 08:00:25.448 src/dds_dns.c#574  DNS client udp new 0x7f780027b0, 223.5.5.5 start, rname:auth.dui.ai
[01-01 18:12:15 TUYA D][simplekv.c:325] create data hd success
[00546:00610]1970-01-01 08:00:25.450 third/mongoose/mongoose.c#12450  dns server: 223.5.5.5
[01-01 18:12:15 TUYA D][simplekv.c:1055] read from normal file
[00546:00610]1970-01-01 08:00:25.451 third/mongoose/mongoose.c#12450  dns server: 114.114.114.114
[DBG]1970-01-01 08:00:25|st_duilite_sspe.c|st_dui_conf(96): read from file: json[{
	"sspeBinPath": "/oem/res/asr_res/sspe/sspe_aec-uda-wkp_30mm_ch3_2mic_1ref_release-v2.0.0.115.bin",
	"wakeupBinPath": "/oem/res/asr_res//wakeup/wakeup_aifar_comm_20180104.bin",
	"env": "words=ni hao mi ya;thresh=0.2;dcheck=1;vad=1;",
	"rollBack": 1200,
	"maxVolume": 0
[DBG]1970-01-01 08:00:25|st_duilite_sspe.c|st_dui_conf(131): outPutDevInfoStr[{
	"rollBack":	1200,
	"maxVolume":	0
[DBG]1970-01-01 08:00:25|st_duilite_sspe.c|dui_sspe_init(415): auth_cfg[{
	"rollBack":	1200,
	"maxVolume":	0
[01-01 18:12:15 TUYA D][simplekv.c:765] curr db is V2. No need to upgrade
[01-01 18:12:15 TUYA D][simplekv.c:555] head check success
[01-01 18:12:15 TUYA D][simplekv.c:658] read and check head success
[01-01 18:12:15 TUYA D][simplekv.c:155] key tls_ca_cnt is invaild, don't crc check
[01-01 18:12:15 TUYA D][simplekv.c:1075] read from normal file success
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:sys_timer,stackDepth:4096,totalstackDepth:4096,priority:5
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:sys_timer Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA D][simplekv.c:1111] init from normal file success.
[DBG]1970-01-01 08:00:25|logic_interactive_comm.c|st_ui_msg_dist_set_deal(5631): cmd :4060
[DBG]1970-01-01 08:00:25|au_page.c|au_page_find_page(527): msg_proc:home_page
[01-01 18:12:15 TUYA D][rcd_file.c:2360] [ty_rcd] udb_mng inited.
[01-01 18:12:15 TUYA D][rcd_file.c:2377] [ty_rcd] db_enc_file_nm:/data/nand-1/TUYACONFIG//rcdDb/tyRcdEncKey.rdb
[DBG]1970-01-01 08:00:25|au_page.c|au_page_create_ctrl(153): ctrl bg_img create
[DBG]1970-01-01 08:00:25|au_page.c|au_page_create_ctrl(153): ctrl home_view create
[DBG]1970-01-01 08:00:25|au_icon.c|ctrl_icon_on_create(88): args->num:2
[DBG]1970-01-01 08:00:25|au_icon.c|ctrl_icon_on_create(96): ctrl_icon_on_create end
[DBG]1970-01-01 08:00:25|au_page.c|au_page_create_ctrl(153): ctrl msg_state create
[DBG]1970-01-01 08:00:25|au_page.c|au_page_create_ctrl(153): ctrl auth_state create
[DBG]1970-01-01 08:00:25|au_icon.c|ctrl_icon_on_create(88): args->num:6
[DBG]1970-01-01 08:00:25|au_page.c|au_page_create_ctrl(153): ctrl wifi_state create
rcd encrypt key 16
c5 46 14 56 ea d1 f8 68 c6 49 27 a5 42 9b d1 b0
[DBG]1970-01-01 08:00:25|au_page.c|au_page_create_ctrl(153): ctrl eth_state create
[DBG]1970-01-01 08:00:25|au_card.c|card_on_create(122): args->drag_max=0
[DBG]1970-01-01 08:00:25|au_page.c|au_page_create_ctrl(153): ctrl card create
[DBG]1970-01-01 08:00:25|au_page.c|au_page_create_ctrl(153): ctrl add_btn create
[DBG]1970-01-01 08:00:25|au_page.c|au_page_create_ctrl(153): ctrl city_btn create
[DBG]1970-01-01 08:00:25|au_page.c|au_page_create_ctrl(153): ctrl time create
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:gw_pool_fast0,stackDepth:8192,totalstackDepth:12288,priority:4
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:gw_pool_fast0 Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:gw_pool_nor0,stackDepth:8192,totalstackDepth:20480,priority:3
[01-01 18:12:15 TUYA D][thread_pool.c:160] get thread id:0x266
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:gw_pool_nor0 Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA D][thread_pool.c:160] get thread id:0x267
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:gw_pool_nor1,stackDepth:8192,totalstackDepth:28672,priority:3
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:gw_pool_nor1 Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA D][thread_pool.c:160] get thread id:0x268
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:gw_pool_tmp0,stackDepth:8192,totalstackDepth:36864,priority:2
[01-01 18:12:15 TUYA D][thread_pool_temp.c:275] create temp 0 in 0x7f80002b20
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:gw_pool_tmp0 Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:gw_pool_tmp1,stackDepth:8192,totalstackDepth:45056,priority:2
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:gw_pool_tmp1 Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA D][thread_pool_temp.c:275] create temp 1 in 0x7f80002b40
[01-01 18:12:15 TUYA D][thread_pool.c:399] thread type:1 idx:0 md:1 name:thr_pool_idle
[01-01 18:12:15 TUYA D][thread_pool.c:437] get thread 1 thr_pool_idle ret:0x7f80002f80
[DBG]1970-01-01 08:00:25|au_page.c|au_page_set_bg(341): page=home_page page->bg=ff2e2e2e
[01-01 18:12:15 TUYA D][thread_pool_temp.c:358] not cycle thread
[DBG]1970-01-01 08:00:25|logic_interactive_comm.c|st_ui_msg_dist_set_deal(5631): cmd :4044
[01-01 18:12:15 TUYA I][mqc_app.c:350] mqc app init ...
[WRN]1970-01-01 08:00:25|ui_logic_interface.c|logic_controlFunc(136): call cmd 4044 cost 1159us
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:cmmod,stackDepth:4096,totalstackDepth:49152,priority:4
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:5 cnt:1
[01-01 18:12:15 TUYA D][mqc_app.c:144] mq_pro:31 cnt:2
[01-01 18:12:15 TUYA D][svc_online_log.c:295] svc online log init success
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:cmmod Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA D][log_seq.c:894] read m:4 f:0 l:3
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:wk_th-0,stackDepth:5120,totalstackDepth:54272,priority:3
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:wk_th-0 Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA D][user_iot_intf.c:300] tuya_iot_init success
[01-01 18:12:15 TUYA N][uni_log.c:197] SetLogManageAttr 4
[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_bi isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA D][simplekv.c:1251] find key:0 gw_bi
[01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_bi find value.Len:144
[01-01 18:12:15 TUYA D][ws_db_gw.c:208] gw base read finish:0
[01-01 18:12:15 TUYA D][tuya_svc_upgrade.c:796] tuya svc upgrade init success!
[01-01 18:12:15 TUYA N][tuya_iot_sdk_api.c:509] gw is enabled
[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_di isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA D][simplekv.c:1251] find key:3 gw_di
[01-01 18:12:15 TUYA D][simplekv.c:1280] key:gw_di find value.Len:400
[01-01 18:12:15 TUYA D][ws_db_gw.c:515] gw_di read success
[01-01 18:12:15 TUYA D][subdev_sto_rcd.c:986] schema id not found
Successfully initialized wpa_supplicant
[01-01 18:12:15 TUYA D][simplekv.c:1211] read key:gw_alarm_flag isFuzzy:0 skipCnt:0
[01-01 18:12:15 TUYA D][simplekv.c:1247] no key find
[01-01 18:12:15 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[01-01 18:12:15 TUYA D][simplekv.c:1336] __read_kv_with_decode fail. -3
[   25.605932] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
[   25.606221] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
[   25.607146] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
[   25.607262] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
[   25.608694] RTW: cfg80211_rtw_get_txpower(wlan0) total max: -10000 mbm
[   25.608876] RTW: rtw_ndev_notifier_call(wlan0) state:4
[   25.620145] RTW: cfg80211_rtw_flush_pmksa(wlan0)
[01-01 18:12:15 TUYA D][thread_pool.c:399] thread type:2 idx:0 md:1 name:async_task
[01-01 18:12:15 TUYA D][thread_pool.c:437] get thread 2 async_task ret:0x7f800034b0
[01-01 18:12:15 TUYA D][thread_pool.c:399] thread type:2 idx:1 md:2 name:reli_http
[01-01 18:12:15 TUYA D][thread_pool.c:437] get thread 2 reli_http ret:0x7f800034d0
[01-01 18:12:15 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-1/TUYACONFIG//rcdDb/gw_cm_kv.rdb, need_backup:1, enable_encrypt:0
[01-01 18:12:15 TUYA D][rcd_file.c:2452] [ty_rcd] normal file exist. bak file not exist
[01-01 18:12:15 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file
[01-01 18:12:15 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success
[01-01 18:12:15 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success
[DBG]1970-01-01 08:00:25|logic_wifi_set.c|net_get_wifi_level(1450):  get add fail !!!
[DBG]1970-01-01 08:00:25|au_icon.c|set_icon_ctrl_index(191): >>>>>>>>>>args->index:0
[DBG]1970-01-01 08:00:25|logic_interactive_comm.c|st_ui_msg_dist_jd_deal(5911): cmd :5009
[ERR]1970-01-01 08:00:25|logic_tuya_jiadian.c|jd_get_scene_list(2426): jd not init or scene list is NULL
[WRN]1970-01-01 08:00:25|ui_logic_interface.c|logic_controlFunc(136): call cmd 5009 cost 1530us
[DBG]1970-01-01 08:00:25|au_page_management_logic.c|management_logic_set_scene_info(258): not scene!
[DBG]1970-01-01 08:00:25|logic_interactive_comm.c|st_ui_msg_dist_jd_deal(5911): cmd :5004
[ERR]1970-01-01 08:00:25|logic_tuya_jiadian.c|jd_get_dev_info(1887): jd not init or out pointer is NULL
[WRN]1970-01-01 08:00:25|ui_logic_interface.c|logic_controlFunc(136): call cmd 5004 cost 1630us
[DBG]1970-01-01 08:00:25|logic_interactive_comm.c|st_ui_msg_regularly_deal(6015): cmd :9002
[DBG]1970-01-01 08:00:25|logic_interactive_comm.c|st_regularly_msg_get_event_list_count(4358): count:0
[WRN]1970-01-01 08:00:25|ui_logic_interface.c|logic_controlFunc(136): call cmd 9002 cost 1522us
[WRN]1970-01-01 08:00:25|ui_logic_interface.c|logic_controlFunc(136): call cmd 9002 cost 1559us
[01-01 18:12:15 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:0
[WRN]1970-01-01 08:00:25|ui_logic_interface.c|logic_controlFunc(136): call cmd 9002 cost 1591us
[01-01 18:12:15 TUYA D][rcd_file.c:2621] [ty_rcd] init [gw_cm_kv] from normal file success.
[01-01 18:12:15 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-1/TUYACONFIG//rcdDb/gw_cm_kv_s.rdb, need_backup:1, enable_encrypt:1
[WRN]1970-01-01 08:00:25|ui_logic_interface.c|logic_controlFunc(136): call cmd 9002 cost 4066us
[01-01 18:12:15 TUYA D][rcd_file.c:2621] [ty_rcd] init [gw_cm_kv_s] from normal file success.
[DBG]1970-01-01 08:00:25|au_page.c|au_page_find_page(527): msg_proc:loadingDialogPage
[01-01 18:12:15 TUYA D][lan_dev_base.c:169] lan_dev_base_set_cap 8000, add 10
[01-01 18:12:15 TUYA D][gw_mgr.c:384] set client num 32
[01-01 18:12:15 TUYA D][gw_mgr.c:390] ignore SIGPIPE
init_dump_info[DBG]1970-01-01 08:00:25|au_page.c|au_page_create_ctrl(153): ctrl loading_page_load_name create
rm: missing operand
Try 'rm --help' for more information.
set stack dump len: 8192
[01-01 18:12:15 TUYA D][tuya_zigbee_api.c:216] ++++++++>{
	"cts":	1,
	"thread_mode":	1,
	"sw_ver":	"1.0.8"
[01-01 18:12:15 TUYA N][tuya_zigbee_api.c:233] zigbee uart cts: 1
cfg_str:{"platform":"GENERIC","mode_id":"SDK","product_key":"NOT USE","wifi_interface":"NOT USE","wan_interface":"NOT USE","net_led":"NOT USE","status_led":"NOT USE","reset_key":"NOT USE","is_sync_systime":false,"is_hardward":false,"storage_dir":"/data/nand-1/TUYACONFIG/","log_dir":"/data/nand-1/TUYACONFIG/","backup_dir":"/data/nand-1/TUYACONFIG/","bin_dir":"/data/nand-1/TUYACONFIG/","tmp_dir":"/tmp/","serial_port":"/dev/ttyS0","is_cts":true}.
[01-01 18:12:15 TUYA D][tuya_zigbee_api.c:95] serial port: /dev/ttyS0, cts: 1
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:ty_zigbee_task,stackDepth:16384,totalstackDepth:70656,priority:5
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:ty_zigbee_task Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:delay_queue,stackDepth:8192,totalstackDepth:78848,priority:3
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:delay_queue Exec Start. Set to Running Stat
[01-01 18:12:15 TUYA I][uni_thread.c:228] thread_create name:slow_queue,stackDepth:8192,totalstackDepth:87040,priority:2
[01-01 18:12:15 TUYA D][uni_thread.c:250] Thread:slow_queue Exec Start. Set to Running Stat
[01-01 18:12:15:302 TUYA D][tuya_z3_api_tmp.c:8208] Tuya host CreateLogManageAndInit init success.
[01-01 18:12:15:311 TUYA D][tuya_z3.c:31491] SUCCESS:tuya_z3_sce_init.
[01-01 18:12:15:311 TUYA E][tuya_iot_ext_api.c:173]  /data/nand-1/TUYACONFIG/engineer_dev_flag.ini is not exist
[01-01 18:12:15:317 TUYA D][simplekv.c:1211] read key:lgw_nkey isFuzzy:0 skipCnt:0
[01-01 18:12:15:317 TUYA D][simplekv.c:1251] find key:5 lgw_nkey
[01-01 18:12:15:318 TUYA D][simplekv.c:1280] key:lgw_nkey find value.Len:144
[01-01 18:12:15:319 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-1/TUYACONFIG//rcdDb/sub_dev_ddi_s.rdb, need_backup:1, enable_encrypt:1
[01-01 18:12:15:325 TUYA D][tuya_z3_host_storage.c:78] ===== zigbee host path print =====
[01-01 18:12:15:325 TUYA D][tuya_z3_host_storage.c:79] bin_dir: /data/nand-1/TUYACONFIG/
[01-01 18:12:15:326 TUYA D][tuya_z3_host_storage.c:80] storage_dir: /data/nand-1/TUYACONFIG/
[01-01 18:12:15:327 TUYA D][tuya_z3_host_storage.c:81] tmp_dir: /tmp/
[01-01 18:12:15:327 TUYA D][tuya_z3_host_storage.c:82] backup_dir: /data/nand-1/TUYACONFIG/
[01-01 18:12:15:328 TUYA D][tuya_z3_host_storage.c:84] ===== zigbee host storage file path print =====
[01-01 18:12:15:329 TUYA D][tuya_z3_host_storage.c:85] zigbee_dev_flag_ini_file: /data/nand-1/TUYACONFIG/devflag.ini
[01-01 18:12:15:330 TUYA D][tuya_z3_host_storage.c:86] zigbee_devices_txt_file: /data/nand-1/TUYACONFIG/devices.txt
[01-01 18:12:15:330 TUYA D][tuya_z3_host_storage.c:87] zigbee_devices1_txt_file: /data/nand-1/TUYACONFIG/devices1.txt
[01-01 18:12:15:331 TUYA D][tuya_z3_host_storage.c:88] zigbee_iaszone_txt_file: /data/nand-1/TUYACONFIG/iaszone.txt
[01-01 18:12:15:332 TUYA D][tuya_z3_host_storage.c:89] NcpUpgrade_backup_ota_file: /data/nand-1/TUYACONFIG/NcpUpgrade_backup.ota
[01-01 18:12:15:333 TUYA D][tuya_z3_host_storage.c:90] NcpUpgrade_backup65_ota_file: /data/nand-1/TUYACONFIG/NcpUpgrade_backup65.ota
[01-01 18:12:15:334 TUYA D][tuya_z3_host_storage.c:91] coo_upgrating_file: /data/nand-1/TUYACONFIG/coo_upgrating
[01-01 18:12:15:335 TUYA D][tuya_z3_host_storage.c:92] coo_upgdate65_file: /data/nand-1/TUYACONFIG/coo_upgdate65
[01-01 18:12:15:336 TUYA D][tuya_z3_host_storage.c:93] zigbee_net_info_file: /data/nand-1/TUYACONFIG/zigbeeNetInfo.txt
[01-01 18:12:15:337 TUYA D][tuya_z3_host_storage.c:94] zigbee_net_info_bak_file: /data/nand-1/TUYACONFIG/zigbeeNetInfo_bak.txt
[01-01 18:12:15:338 TUYA D][tuya_z3_host_storage.c:95] zigbee_net_info_valid_file: /data/nand-1/TUYACONFIG/zigbee_net_valid_flag
[01-01 18:12:15:339 TUYA D][tuya_z3_host_storage.c:97] ===== zigbee host tmp file path print =====
[01-01 18:12:15:340 TUYA D][tuya_z3_host_storage.c:98] zigbee_ota_dir: /tmp/ota-files
[01-01 18:12:15:340 TUYA D][tuya_z3_host_storage.c:99] zigbee_ncp_ug_file: /tmp/ota-files/NcpUpgrade.ota
[01-01 18:12:15:341 TUYA D][tuya_z3_host_storage.c:100] zigbee_dev_ug_file: /tmp/ota-files/ZigbeeDevUpgrade.ota
[01-01 18:12:15:342 TUYA D][tuya_z3_host_storage.c:101] zigbee_ncp_ver_file: /tmp//ncp_ver65_1_0_10_flag
Success: _Z3MsgSendToInit.
Success: _MsgRecvformInit.
=====devFileInit=====
[01-01 18:12:15:346 TUYA D][rcd_file.c:2452] [ty_rcd] normal file exist. bak file not exist
fileFlag is 0
[01-01 18:12:15:346 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file
[01-01 18:12:15:347 TUYA D][tuya_z3_api_tmp.c:8257]  argc1 = 3
[01-01 18:12:15:347 TUYA D][tuya_z3_api_tmp.c:8259]  argv[0] = ./build/exe/Z3GatewayHost
[01-01 18:12:15:348 TUYA D][tuya_z3_api_tmp.c:8260]  argv[1] = -p
[01-01 18:12:15:348 TUYA D][tuya_z3_api_tmp.c:8261]  argv[2] = /dev/ttyS0
[01-01 18:12:15:349 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success
[01-01 18:12:15:350 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success
[01-01 18:12:15:350 TUYA D][af-main-host.c:936] Reset info: 11 (SOFTWARE)
[01-01 18:12:15:351 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:0
=== ASH started ===
[01-01 18:12:15:351 TUYA D][rcd_file.c:2621] [ty_rcd] init [sub_dev_ddi_s] from normal file success.
ty_uart_init begin
[01-01 18:12:15:352 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-1/TUYACONFIG//rcdDb/sub_dev_schm.rdb, need_backup:1, enable_encrypt:0
uartMutexInit suceess[01-01 18:12:15:354 TUYA D][rcd_file.c:2452] [ty_rcd] normal file exist. bak file not exist
[01-01 18:12:15:355 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file
ty_uart_recv start
ty_uart_recv end
ty_uart_init end ,status:0.
[DBG]1970-01-01 08:00:25|au_page.c|au_page_create_ctrl(153): ctrl loading_page_lable_name create
[01-01 18:12:15:356 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success
[DBG]1970-01-01 08:00:25|au_setLoadingDialog.c|msg_set_dialog_type(134): page_args->text_type:0
[DBG]1970-01-01 08:00:25|au_page.c|au_page_set_bg(341): page=loadingDialogPage page->bg=0
[1] nwakeup chn [1], entry feed thread
[1] nwakeup chn [2], entry feed thread
status:0x76.
[01-01 18:12:15:357 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success
[1] nwakeup chn [3], entry feed thread
[01-01 18:12:15:360 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:0
[1] nwakeup chn [0], entry feed thread
0x2e [01-01 18:12:15:362 TUYA D][rcd_file.c:2621] [ty_rcd] init [sub_dev_schm] from normal file success.
0x8f 0xb1 0x57 0x54 0xd8 0x36 0x54 0xff
ASH_FLAG TUYA check.
ASH_FLAG TUYA check, abnormal_data_num:9.
[01-01 18:12:15:363 TUYA D][rcd_file.c:2443] [ty_rcd] rcd file name:/data/nand-1/TUYACONFIG//rcdDb/s_dev_schm_ver.rdb, need_backup:1, enable_encrypt:0
[01-01 18:12:15:365 TUYA D][rcd_file.c:2452] [ty_rcd] normal file exist. bak file not exist
[01-01 18:12:15:365 TUYA D][rcd_file.c:2492] [ty_rcd] read from normal file
[01-01 18:12:15:367 TUYA D][rcd_file.c:894] [ty_rcd] create data hd success
[WRN]1970-01-01 08:00:25|ui_logic_interface.c|logic_controlFunc(136): call cmd 5009 cost 7823us
[DBG]1970-01-01 08:00:25|st_duilite_sspe.c|dui_sspe_init(441): inputWavChan = 3
[DBG]1970-01-01 08:00:25|st_duilite_sspe.c|dui_sspe_init(443): outputWavChan = 4
[DBG]1970-01-01 08:00:25|st_duilite_sspe.c|dui_sspe_init(445): wkpWavChan = 4
[DBG]1970-01-01 08:00:25|st_duilite_sspe.c|dui_sspe_init(447): aecWavChan = 2
[WRN]1970-01-01 08:00:25|ui_logic_interface.c|logic_controlFunc(136): call cmd 5004 cost 2935us
[DBG]1970-01-01 08:00:25|st_duilite_sspe.c|dui_sspe_init(449): vprintWavChan = 5
[DBG]1970-01-01 08:00:25|st_duilite_sspe.c|dui_sspe_init(450): bfWavChan = 3
[DBG]1970-01-01 08:00:25|st_duilite_sspe.c|dui_sspe_init(451): vpCbLen = 2593
[WRN]1970-01-01 08:00:25|ui_logic_interface.c|logic_controlFunc(136): call cmd 9002 cost 2873us
[DBG]1970-01-01 08:00:25|st_duilite_sspe.c|dui_sspe_init(452): doa = 0
[DBG]1970-01-01 08:00:25|asr_export_api.c|st_asr_dui_init(1835): vadConfPath[/oem/res/asr_res//vad.conf]
[DBG]1970-01-01 08:00:25|st_duilite_vad.c|st_dui_conf(100): read from file: json[{
	"resBinPath": "/oem/res/asr_res/vad/vad_aihome_v0.12c.bin",
	"pauseTime": 300,
	"fullMode": 0
[WRN]1970-01-01 08:00:25|ui_logic_interface.c|logic_controlFunc(136): call cmd 9002 cost 2992us
[DBG]1970-01-01 08:00:25|st_duilite_vad.c|st_dui_conf(122): outPutDevInfoStr[{
	"pauseTime":	300,
	"fullMode":	0
[DBG]1970-01-01 08:00:25|st_duilite_vad.c|dui_vad_init(374): auth_cfg[{
	"pauseTime":	300,
	"fullMode":	0
[01-01 18:12:15:367 TUYA D][rcd_file.c:2507] [ty_rcd] read from normal file success
[WRN]1970-01-01 08:00:25|ui_logic_interface.c|logic_controlFunc(136): call cmd 9002 cost 4347us
[01-01 18:12:15:389 TUYA D][rcd_file.c:972] [ty_rcd] udb->rcd_valid_cnt:0
[01-01 18:12:15:390 TUYA D][rcd_file.c:2621] [ty_rcd] init [s_dev_schm_ver] from normal file success.
[01-01 18:12:15:391 TUYA D][simplekv.c:1211] read key:ddi- isFuzzy:1 skipCnt:1
[01-01 18:12:15:392 TUYA D][simplekv.c:1247] no key find
[WRN]1970-01-01 08:00:25|ui_logic_interface.c|logic_controlFunc(136): call cmd 9002 cost 2965us
[01-01 18:12:15:393 TUYA D][simplekv.c:1294] __read_kv_raw fail. -3
[01-01 18:12:15:395 TUYA D][subdev_sto_rcd.c:147] ddi fuzzy read  -6. maybe not exist
[01-01 18:12:15:396 TUYA D][subdev_sto_rcd.c:224] old plain db not exist
[01-01 18:12:15:396 TUYA D][simplekv.c:1211] read key:uz3-devices isFuzzy:0 skipCnt:0
[01-01 18:12:15:397 TUYA D][simplekv.c:1251] find key:2 uz3-devices
[01-01 18:12:15:397 TUYA D][simplekv.c:1280] key:uz3-devices find value.Len:16
[01-01 18:12:15:398 TUYA D][tuya_z3.c:31502] SUCCESS:tuya_z3_NetDataInit.
[01-01 18:12:15:398 TUYA D][thread_pool.c:399] thread type:2 idx:0 md:3 name:tuya_packet_trans
[01-01 18:12:15:400 TUYA D][thread_pool.c:437] get thread 2 tuya_packet_trans ret:0x7f800034b0
[01-01 18:12:15:400 TUYA D][tuya_z3_packet.c:314] tuya svc packet init success!
[01-01 18:12:15:401 TUYA D][tuya_z3.c:31513] SUCCESS:tuya_z3_packet_init.
[01-01 18:12:15:401 TUYA D][tuya_gw_z3_user.c:118] z3 user dev loading...
[01-01 18:12:15:402 TUYA D][simplekv.c:1211] read key:uz3-devices isFuzzy:0 skipCnt:0
[01-01 18:12:15:403 TUYA D][simplekv.c:1251] find key:2 uz3-devices
[01-01 18:12:15:403 TUYA D][simplekv.c:1280] key:uz3-devices find value.Len:16
[01-01 18:12:15:404 TUYA D][tuya_gw_z3_user.c:129] z3_dev_db: []
[01-01 18:12:15:404 TUYA D][tuya_z3.c:31536] tuya_z3_init status: 0, isUg=0
[01-01 18:12:15:410 TUYA I][uni_thread.c:228] thread_create name:ty_z3_msg,stackDepth:8192,totalstackDepth:95232,priority:5
[01-01 18:12:15:414 TUYA D][uni_thread.c:250] Thread:ty_z3_msg Exec Start. Set to Running Stat
[   25.852196] Freeing drm_logo memory: 676K
[WRN]1970-01-01 08:00:25|st_duilite_vad.c|st_dui_vad_start(250):   g_vadStartFlg : 1
[DBG]1970-01-01 08:00:25|asr_export_api.c|st_asr_dui_init(1848): asrConfPath[/oem/res/asr_res//asr.conf]
[DBG]1970-01-01 08:00:25|st_duilite_asr.c|dui_asr_init(337): gramConfPath[/oem/res/asr_res//gram.conf]
[DBG]1970-01-01 08:00:25|st_duilite_gram.c|st_dui_new_conf(237): read from file: json[{
	"newConf": {
		"resBinPath": "/oem/res/asr_res/asr/ebnfc.aicar.1.2.0.bin"
	"startConf": {
		"outputPath": "/data/nand-1/ASR/netBinAsr",
		"ebnfFile": "/oem/res/asr_res/gram.xbnf"
[DBG]1970-01-01 08:00:25|st_duilite_gram.c|st_dui_new_conf(263): outPutDevInfoStr[{
[DBG]1970-01-01 08:00:25|st_duilite_gram.c|st_dui_start_conf(168): read from file: json[{
	"newConf": {
	"startConf": {
[DBG]1970-01-01 08:00:25|st_duilite_gram.c|st_dui_start_conf(194): outPutDevInfoStr[{
[DBG]1970-01-01 08:00:25|st_duilite_asr.c|st_dui_conf(97): read from file: json[{
	"resBinPath": "/oem/res/asr_res/asr/ebnfr.aicar.1.3.0.bin",
	"netBinPath": "/data/nand-1/ASR/netBinAsr"
[DBG]1970-01-01 08:00:25|st_duilite_asr.c|st_dui_conf(120): outPutDevInfoStr[{
[DBG]1970-01-01 08:00:25|st_duilite_asr.c|dui_asr_init(352): auth_cfg[{
[WRN]1970-01-01 08:00:26|hw_ioctrl_api.c|hw_speak_off(597): hw_speak_off
[WRN]1970-01-01 08:00:26|hw_ioctrl_api.c|hw_spk_amp_on(536): hw_spk_amp_on
[DBG]1970-01-01 08:00:26|logic_distribute.c|net_direct_send(572): address = 0, cmd = ff54
============start====value:279=====
[DBG]1970-01-01 08:00:26|logic_sys_scene.c|st_sys_screensaver_ontime(124): no use screen saver !!!
[DBG]1970-01-01 08:00:26|st_dds_asr.c|st_dds_conf(457): read from file: json[{
	"aliasKey": "test",
	"savedProfile": "/data/nand-1/ASR/dds.lic",
	"devInfo": {
		"instructionSet": "armv7",
	"prof": {
		"enable": 1,
		"level": 1,
		"output": "/data/asr_dds.log"
[DBG]1970-01-01 08:00:26|st_dds_asr.c|st_dds_conf(601): val_productId[279613643], val_aliasKey[test], val_productKey[8c1165eeec8d32dfdce2f3a9855e401b], val_productSecret[64c7f7a26b1816a4d4693848f0007bcb], val_savedProfile[/data/nand-1/ASR/dds.lic], outPutDevInfoStr[{
	"clientName":	"ZKA1MVG18-100101-REL",
	"instructionSet":	"V1.01.0001_11:51:14_Mar 17 2023"
[WRN]1970-01-01 08:00:26|st_dds_asr.c|st_dds_conf(618): val_logOutput[/data/asr_dds.log]
[DBG]1970-01-01 08:00:26|st_dds_asr.c|st_dds_ev_ccb(349): : default:type[15]
[DBG]1970-01-01 08:00:26|asr_export_api.c|st_asr_dds_callbak(1283): cmd: 30
[DBG]1970-01-01 08:00:26|asr_export_api.c|st_asr_dds_ev_deal(1265): : default:type[15]
[DBG]1970-01-01 08:00:26|st_dds_asr.c|st_dds_ev_ccb(333): : DDS_EV_OUT_DUI_LOGIN
[DBG]1970-01-01 08:00:26|st_dds_asr.c|st_dds_ev_login(156): deviceName: 00:00:11:22:33:47
[DBG]1970-01-01 08:00:26|st_dds_asr.c|st_dds_ev_login(162): encryptProfile: 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
[DBG]1970-01-01 08:00:26|asr_export_api.c|st_asr_dds_ev_deal(1249): : DDS_EV_OUT_DUI_LOGIN
[DBG]1970-01-01 08:00:26|asr_export_api.c|st_asr_dds_ev_login(896): deviceName: 00:00:11:22:33:47
[DBG]1970-01-01 08:00:26|asr_export_api.c|st_asr_dds_ev_login(901): encryptProfile: 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
[DBG]1970-01-01 08:00:26|st_alsa_dev.c|st_alsa_format_from_avformat(338): avFormat: 1
[DBG]1970-01-01 08:00:26|st_alsa_dev.c|st_alsa_params_init(391): Channel[4], Format[2], SampleRate[16000], BlockTime[20]
[WRN]1970-01-01 08:00:26|st_alsa_dev.c|st_alsa_set_params(575): HW Params of device "hw:1,0":
[WRN]1970-01-01 08:00:26|st_alsa_dev.c|st_alsa_set_params(576): --------------------
ACCESS:  MMAP_INTERLEAVED RW_INTERLEAVED
FORMAT:  S16_LE S24_LE S32_LE
SUBFORMAT:  STD
SAMPLE_BITS: [16 32]
FRAME_BITS: [32 256]
CHANNELS: [2 8]
RATE: [8000 192000]
PERIOD_TIME: (41 8192000]
PERIOD_SIZE: [8 65536]
PERIOD_BYTES: [256 1900800]
PERIODS: [2 16384]
BUFFER_TIME: (83 16384000]
BUFFER_SIZE: [16 131072]
BUFFER_BYTES: [256 524288]
TICK_TIME: ALL
[WRN]1970-01-01 08:00:26|st_alsa_dev.c|st_alsa_set_params(578): --------------------
[WRN]1970-01-01 08:00:26|st_alsa_dev.c|st_alsa_set_params(651):  actual available rate is [16000] !!!
[WRN]1970-01-01 08:00:26|st_alsa_dev.c|st_alsa_set_params(652): buffer_time[80000], buffer_frames[0]
[WRN]1970-01-01 08:00:26|st_alsa_dev.c|st_alsa_set_params(666): period_time[20000], period_frames[0]
[WRN]1970-01-01 08:00:26|st_alsa_dev.c|st_alsa_set_params(688): period_time[20000], period_frames[0]
[WRN]1970-01-01 08:00:26|st_alsa_dev.c|st_alsa_set_params(689): buffer_time[80000], buffer_frames[0]
[   26.180634] clk_pdm_frac parent_rate(589823999) is low than rate(40960000)*20, fractional div is not allowed
[   26.180681] clk_pd[DBG]1970-01-01 08:00:26|st_malsa_dev.c|st_alsa_set_params(725): chunk_size[320], buffer_size[1280]
ACCESS:  RW_INTERLEAVED
FORMAT:  S16_LE
SUBFORMAT:  STD
SAMPLE_BITS: 16
FRAME_BITS: 64
CHANNELS: 4
RATE: 16000
PERIOD_TIME: 20000
PERIOD_SIZE: 320
PERIO_D_BYTES: 2560
PERIODS: 4
BUfFFER_TIME: 80000
BUFFER_SIZEr: 1280
aUFFER_BYTES: 10240
 TICK_TIME: 0
c parent_rate(5[DBG]1970-01-01 08:00:26|st_8alsa_dev.c|st_alsa_set_param9(788):  alsa set params return ok !!!!
823999) is low than rate(98304000)*20, fractional div is not allowed
[   26.[DBG]1970-01-01 08:00:26|st_alsa_dev.c|st_alsa_pcm_read_thread(812): count: 320
180697] clk_pdm_frac parent_rate(589823999) is low than rate(98304000)*20, fractional div is not allowed
[DBG]1970-01-01 08:00:26|st_dds_asr.c|st_dds_ev_ccb(308): : DDS_EV_OUT_STATUS
[WRN]1970-01-01 08:00:26|st_dds_asr.c|st_dds_ev_out_status(273): dds cur status: DDS_STATUS_IDLE
[DBG]1970-01-01 08:00:26|asr_export_api.c|st_asr_dds_ev_deal(1214): : DDS_EV_OUT_STATUS
[WRN]1970-01-01 08:00:26|logic_wifi_set.c|st_event_callback(140): wifi status event: 6
[DBG]1970-01-01 08:00:26|logic_wifi_set.c|st_init_wifi_thread(945): wifi enable success
[DBG]1970-01-01 08:00:26|logic_wifi_set.c|st_wpa_cli_connect(598): waite for connect to TP-LINK_ZNZD
[DBG]1970-01-01 08:00:26|logic_wifi_set.c|st_init_wifi_thread(1002): start connect to TP-LINK_ZNZD
udhcpc: started, v1.27.2
udhcpc: sending discover
udhcpc: received SIGTERM
[   26.577801] rk_gmac-dwmac ff4e0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[   26.577888] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[01-01 18:12:16:414 TUYA D][tuya_z3.c:31536] tuya_z3_init status: 1, isUg=0
[   27.529060] RTW: cfg80211_rtw_scan(wlan0)
[   27.529438] RTW: [HW_VAR_CHECK_TXBUF] no packet in tx packet buffer (0)
[   27.529928] RTW: wlan0 sleep m0=0x00000002, ori reg_0x4d4=0x00000000
[DBG]1970-01-01 08:00:27|logic_wifi_set.c|net_get_wifi_level(1450):  get add fail !!!
[DBG]1970-01-01 08:00:27|au_icon.c|set_icon_ctrl_index(191): >>>>>>>>>>args->index:1
 1 Jan 08:00:27 ntpd[434]: Listen normally on 7 eth0 192.168.8.175:123
 1 Jan 08:00:27 ntpd[434]: Deleting interface #5 eth0, fe80::a027:19af:38a3:5fa8%2#123, interface stats: received=0, sent=0, dropped=0, active_time=21 secs
 1 Jan 08:00:27 ntpd[434]: Deleting interface #6 eth0, 192.168.0.10#123, interface stats: received=0, sent=0, dropped=0, active_time=18 secs
ASH connected
Tried to remove head from an empty queue
lvgl_main: /root/workspace_temp/EmbedSDKs/ty_integrated_sdk/ty_integrated_sdk/sdk/zigbee_host/slabs/v2.2/protocol/zigbee/app/ezsp-host/ezsp-host-queues.c:129: ezspRemoveQueueHead: Assertion `false' failed.
signal recv:6  crash cb:(nil)
after crash cb
pid=546 tid=629 get_thread_name=ty_zigbee_task
gen dump file /data/nand-1/TUYACONFIG//crash//629_ty_zigbee_task_27
stack_addr=0x7f73ac3ef4
read [/proc/546/maps] ret:12284
stack_addr_start=0x7f73ac7000
stack dump:
0000000000000010 0000007f73ac7000 0000000173ac3f10 7564206b63617473
3031303030303030 3730303030303020 3030376361333766 3030303030302030
3733333331363336 3330333033203636 3230333033303330 000000000a303330
0000000000000000 0000000000000000 0000000000000000 0000000000000000
0000000000000000 0000000000000000 0000000000000000 0000000000002000
0000007f73ac3ef4 0000007f73ac4000 0000007f73ac53e0 0000007fb54566c0
0000000000000000 0000000600000000 0000000000000000 656267697a5f7974
00006b7361745f65 0000000000000000 0000000000000000 0000000000000000
0000000000000000 0000000000000000 0000000000000000 72206c616e676973
59000a363a766365 2f4749464e4f4341 2f2f68736172632f 7a5f79745f393236
61745f6565626769 00000037325f6b73 0000000000000000 0000000000000000
0000000000000000 0000000000000000 0000000000000000 0000003800000000
000000000000001b 0000027500000222 0000000000000000 0000000000000000
0000000000000000 0000000000000002 0000000000000000 0000000000000000
0000000000000000 0000000000000000 0000007f73ac5410 0000000000000000
0000000000000008 0000000000000000 0000007f73ac5410 ffffffffffffffff
ffffffffffffffff 0000000000000087 ffffffffffffffff ffffffffffffffff
ffffffffffffffff ffffffffffffffff ffffffffffffffff 0000000000000000
0000000000000078 0000007fb2c54030 0000007fb2b84b08 0000000000000000
0000000000000006 0000007f73ac61d0 0000007fb2c55a70 0000007fb30fcb60
0000000000000081 0000007fb2e3fcb0 0000000000000000 0000007f732c6000
0000007f8000e500 0000000000000000 0000007f73ac53f0 0000007fb2b41038
0000007f73ac53f0 0000007fb2b410ac 0000000000000000 0000000000000000
0000021046508001 0000000000000000 2525252525252525 2525252525252525
0000005849534f50 000000000000203a 0000000000007325 253a732573257325
ffffff0000000000 ffffffffffff0000 ffffffffffff0000 0000000000000000
4010040000000000 4010040140100000 4010040140100001 4000000100100001
4010040140100401 4010040140100401 0000000000000000 0000000000000000
0000000000000000 0000000000000000 4111555155505400 4111555155505400
000010000000aaaa 0000000010000000 0010000000000000 0000000000000000
[01-01 18:12:17:515 TUYA D][tuya_z3.c:31536] tuya_z3_init status: 1, isUg=0
0000007f73ac4d90 0000007fb2b84680 0000007f68000020 000000000000012c
0000000000000064 0000007f68003220 000000000000008e 000000000000012c
0000007f73ac5470 0000007f73ac5470 0000007fb2c517f0 000000000000000b
0000007f73ac4dc0 0000007fb2b7f72c 0000007f73ac5470 0000000000000076
0000000000000064 0000007f68003220 0000007f68003290 000000000000012c
0000007f73ac4dc0 0000007fb2b7f754 0000007f73ac5470 000000000000000b
0000007f73ac5470 0000000000000076 0000007f73ac4dc0 0000000000000000
0000007f73ac4e00 0000007fb2b7e2f4 0000007fb2c517f0 0000007fb30fcbba
0000007f73ac4e00 0000007fb2b7e31c 0000000000000034 0000000000000bd0
0000007f73ac4e70 0000007fb2b55314 0000007fb2c2a998 0000007fb2c50d70
0000007f73ac68c0 0000000000000048 0000007fb2c2a998 0000000000000000
0000007f73ac5450 0000007f73ac5560 0000007f73ac4e70 0000007fb2bcbf3c
0000000000000000 00000002732c6000 0000007f73ac5410 0000007fb2b79038
0000007f73ac5470 0000007f73ac56b8 0000007fb2c2a998 0000007f68003220
0000007f73ac5570 0000007fb2e3fcb0 0000000000000000 0000007f732c6000
0000007f8000e500 0000000000000000 0000000000000020 0000000000000000
0000000000000000 0000000000000001 0000007f00000075 0000007f0000000a
0000007f00000000 0000007f00000005 0000007f73ac54b0 0000007fb2b6f4e8
0000007fb2c55440 0000007f73ac61d0 0000007fb2c2a998 0000007f73ac5560
0000007f8000e500 0000000000000000 0000007f73ac5670 00000000ffffff80
0000000000000020 0000000000000000 0000007f73ac5530 0000007fb2b5b948
0000007f73ac5770 0000007fb2c2a9c0 0000007f73ac4fd0 0000007fb2bcbf3c
0000007f73ac61d0 00000002b2e3fcb0 0000007f73ac5000 0000007fb2b7beb0
000000000000002a 0000007f73ac5660 0000007f73ac5660 0000007f73ac5630
00000016ffffffd0 0000007f73ac5660 0000007f73ac5660 ffffffd0ffffff80
0000007f73ac5660 0000007f73ac5660 0000007f73ac5630 ffffff80ffffffd0
000000000000002a 0000000000000000 0000007fb2c55520 0000007fb3101a7b
0000007fb2c515f8 0000000000000001 0000007f73ac5090 0000007fb2b7c59c
0000000000000002 0000007fb30fc1f7 0000007f73ac50f0 0000007fb2b55314
0000007fb3101a50 0000007fb2c50d70 0000007f73ac50f0 0000007fb2b549ac
0000007fb3101a77 0000007fb2b55314 0000007fb30fc1e8 0000007fb2c50d70
0000007f73ac5120 0000007fb2b549ac 0000007f73ac5690 0000007fb2b5b948
000000000000000b 0000007fb044f340 0000007fb044f2be 0000007fb044f2bf
0000007f73ac61d0 0000007fb2e3fcb0 0000000000000000 0000007f732c6000
0000000000000000 0000000000000001 0000007f00000075 000000000000000a
0000007f73ac5690 0000000000000001 0000007fb2c258a8 0000000000000000
0000000000000000 0000007fb2c255f0 ffffffffffffffff 0000000000000001
0000007fb2b54e68 0000000000000000 0000000000000bd0 0000007f73ac5760
0000001600000001 0000007f73ac57a0 0000007f73ac57a0 ffffffd0ffffff80
0000000000000bd0 0000007f73ac5790 0000001600000001 0000007f73ac57c0
0000007f73ac57c0 0000007fb3101a7b 0000000000000000 0000007fb2c255f0
ffffffffffffffff 0000007f00000001 0000007fb2b54e68 0000007fb30fc1f7
0000000000000bd0 0000007f73ac57a0 0000007f73ac57a0 0000007f73ac5760
ffffff80ffffffc8 0000007fb4dd9cd8 0000007fb2c55520 0000007f00000000
0000000000000000 0000007f00000000 ffffff80ffffffd0 0000007fb4dd9cd8
0000007fb2c55520 0000000000000000 0000000000000000 0000000000000001
0000000000000bd0 0000007f73ac5870 0000007f73ac5370 0000007fb2b8343c
0000007f68003290 0000007f68003280 0000007f680033c0 0000007f68000020
00000000000000cf 0000000000000140 0000007f68000020 0000007f732c6000
0000007f8000e500 0000000000000000 0000007fb2c2a998 0000007fb30fcb60
0000007f73ac5570 0000000000000000 0000007f73ac53b0 0000007fb2b84eb8
0000007f68003290 0000007f68003280 00000000000000ce 00000000000000e0
0000007f73ac53e0 0000007fb2b7fac8 0000007f73ac5410 0000007fb2b790b4
00000000000000ce 0000007f73ac56b8 00000000000000ce 00000000000000cf
0000007f73ac53f0 0000007fb2b41038 0000007f73ac5510 0000007fb2b423d4
0000007fb2c55000 0000000068003220 0000000000000000 0000007fb2b5ba98
0000007fb30fcd08 0000007fb30fcbf0 0000007fb2c2a998 0000007fb30fcb60
0000000000000081 0000007fb54497e0 0000007f73ac5660 0000007f73ac5660
0000007f73ac5510 0000007fb2b4231c 0000007fb2c55000 0000007f73ac61d0
0000007f73ac5510 0000007fb2b424f0 fffffffe7fffffff ffffffffffffffff
ffffffffffffffff ffffffffffffffff ffffffffffffffff ffffffffffffffff
ffffffffffffffff ffffffffffffffff 0000007f73ac5670 0000007fb2b3a93c
0000007fb5448000 0000007fb30fcbf0 0000007fb2c2a998 0000007fb2b3a8a8
0000007fb30fcd08 0000000000000020 0000000000000000 0000000000000000
0000000000000000 7463657000000000 726f727265206465 0000000000000a2e
0000007f73ac5670 0000007fb2b3a938 0000007fb5448000 0000007fb30fcbf0
0000007fb2c2a998 0000007fb30fcb60 0000000000000081 0000007fb2e3fcb0
0000000000000000 0000007f732c6000 0000007f8000e500 0000000000000000
0000007fb30fcd08 0000007fb30fcbf0 0000007f73ac5670 0000007f00000000
0000007fb30fcbf0 0000007f73ac56b4 0000007f73ac56c0 0000007fb2b3a9d4
0000007fb30fcbf0 0000007fb30fcb60 0000000000000081 0000007fb30fcd08
0000007f73ac61d0 ffffffffff000000 0000100000000000 0000007f68003290
0000007f73ac56f0 0000007fb304dfb4 000000000000000b 0000007fb044f340
0000007fb044f2be 0000007fb044f2bf 0000007f73ac5720 0000007fb304cdd4
0000000000000000 0000007fb3141230 0000007fb5455000 0000000000000000
0000007f73ac5740 0000007fb304ba5c 0005007fb3122a80 0000007fb313d4e0
0000007f73ac5760 0000007fb304b50c 0000007f73ac5760 00010001b3141220
0000007f73ac5780 0000007fb304d578 0000007f73ac5780 0100000000000000
0000007f73ac57b0 0000007fb30226cc 0000000000000000 0000000000000000
0000000000000000 2710040140000000 0000007f73ac57d0 0000007fb3022d88
0000007fb3122360 27000203b3022d90 0000007f73ac57f0 0000007fb301d248
0000007fb31274d8 01000004b301d244 0000007f73ac5830 0000007fb3016d8c
4000000000000000 0000007fb313b396 0000007f73ac584f 0710040140100401
0000007fb3121260 0000007fb3016d8c 0000007f73ac5860 0000007fb30156c0
4010040140100401 4010040140100401 0000007fb3126c98 0700007fb30156c0
0000007f73ac5890 0000007fb3015c04 4010040140100401 4010040140100401
0000007fb3124218 0000007fb3015c04 0000007f73ac58d0 0000007fb30137d0
0000007f73ac61d0 4010040140100001 0000007f73ac5910 0000000340100401
00000000b3120958 0000000000000000 0000007f73ac5940 0000007fb3013598
0000000100000000 0000007fb313a7f8 0000007fb313a97c 0000007fb313ab7c
0000007fb313a87c 0000007fb313aa7c 0000007fb30ed7d0 0000007fb30ed800
0000007fb313a7f8 0000000000000000 0000000000000000 0000000300000000
0000007f73ac5960 0000007fb2dec3bc 0000000000000001 0000007fb313a7f8
0000007f73ac5990 0000007fb2e3fcf4 0000000000000000 0000007f800147b0
0000000000000000 0000007f800147b0 0000007f73ac59c0 0000007fb4dce0e8
0000007f73ac59c0 0000007f8000e500 0000007f73ac61d0 0000007f8000e500
0000000000000000 0000007fb2bd874c 0000007f73ac61d0 0000007fb044f340
0000007fb044f2be 0000000000000000 0000000000000000 0000007f73ac61d0
0000000000000000 0000007f73ac61d0 0000007fb044f340 0000007fb044f2be
0000007fb044f2bf 0000007f73ac61d0 0000007fb2e3fcb0 0000000000000000
0000007f732c6000 0000007f8000e500 0000000000000000 0000007f73ac59c0
bab425fb5d1faf28 0000000000000000 bab425fb9a6f1654 0000000000000000
stack dump End
dump text section
00400000-004ec000 r-xp 00000000 1f:07 2                                  /oem/bin/lvgl_main
7fb03b6000-7fb03c6000 r-xp 00000000 1f:06 561                            /lib/libresolv-2.26.so
7fb03da000-7fb03de000 r-xp 00000000 1f:06 555                            /lib/libnss_dns-2.26.so
7fb03ef000-7fb03f8000 r-xp 00000000 1f:06 557                            /lib/libnss_files-2.26.so
7fb2906000-7fb293b000 r-xp 00000000 1f:06 1260                           /usr/lib/libpcre.so.1.2.9
7fb294c000-7fb2954000 r-xp 00000000 1f:06 1326                           /usr/lib/libwpa_client.so
7fb2965000-7fb2983000 r-xp 00000000 1f:06 1049                           /usr/lib/libbluetooth.so.3.18.16
7fb2996000-7fb29d3000 r-xp 00000000 1f:06 1064                           /usr/lib/libdbus-1.so.3.19.4
7fb29e6000-7fb2ac7000 r-xp 00000000 1f:06 1112                           /usr/lib/libglib-2.0.so.0.5400.2
after dump. fsync
sig_proc over
[   28.571862] RTW: rtw_process_beacon_hint: change ch:12 to active
[   28.679644] dclk_vop_frac parent_rate(260000000) is low than rate(15000000)*20, fractional div is not allowed
[   28.679747] rockchip-vop ff2e0000.vop: [drm:vop_crtc_enable] Update mode to 480x480p60, type: 17
[   28.679826] dclk_vop_frac parent_rate(260000000) is low than rate(14942000)*20, fractional div is not allowed
[   28.907025] RTW: wlan0 wakeup m0=0x00000002, ori reg_0x4d4=0x00000002
[   28.907158] RTW: survey done event(41) band:0 for wlan0
[   28.907822] RTW: rtw_indicate_scan_done(wlan0)
[   28.916778] RTW: =>cfg80211_rtw_connect(wlan0) - Start to Connection
[   28.916856] RTW: privacy=1, key=          (null), key_len=0, key_idx=0, auth_type=0
[   28.916911] RTW: ssid=TP-LINK_ZNZD, len=12
[   28.916951] RTW: bssid=30:fc:68:61:5e:a6
[   28.916975] RTW: rtw_cfg80211_set_wpa_version, wpa_version=2
[   28.916999] RTW: rtw_cfg80211_set_auth_type, nl80211_auth_type=0
[   28.917023] RTW: cfg80211_rtw_connect, ie_len=22
[   28.917048] RTW: set wpa_ie(length:22):
[   28.917072] RTW: 30 14 01 00  00 0F AC 04  01 00 00 0F  AC 04 01 00
[   28.917268] RTW: 00 0F AC 02  00 00
[   28.917366] RTW: got wpa2_ie, wpa2_ielen:20
[   28.917620] RTW: rtw_cfg80211_set_cipher, ucast=1, cipher=0xfac04
[   28.917706] RTW: rtw_cfg80211_set_cipher, ucast=0, cipher=0xfac04
[   28.917753] RTW: rtw_cfg80211_set_key_mgt, key_mgt=0xfac02
[   28.917812] RTW: rtw_set_802_11_connect(wlan0)  fw_state=0x00000008
[   28.917900] RTW: [by_bssid:1][assoc_ssid:TP-LINK_ZNZD][to_roam:0] new candidate: TP-LINK_ZNZD(30:fc:68:61:5e:a6, ch11) rssi:-53 dBm
[   28.917942] RTW: rtw_select_and_join_from_scanned_queue: candidate: TP-LINK_ZNZD(30:fc:68:61:5e:a6, ch:11)
[   28.917982] RTW: link to new AP
[   28.918040] RTW: [HT] HAL Support STBC = 0x01
[   28.918073] RTW: [HT] Declare supporting RX STBC = 1
[   28.918100] RTW: rtw_restructure_ht_ie IEEE80211_HT_CAP_MAX_AMSDU is set
[   28.918157] RTW: set ssid:dot11AuthAlgrthm=2, dot11PrivacyAlgrthm=4, dot118021XGrpPrivacy=4
[   28.918187] RTW: <=cfg80211_rtw_connect, ret 0
[   28.918248] RTW: rtw_chk_start_clnt_join(wlan0) req: 11,1,2
[   28.918299] RTW: rtw_chk_start_clnt_join(wlan0) others ld_sta_num:0, ap_num:0, mesh_num:0
[   28.918328] RTW: rtw_chk_start_clnt_join(wlan0) union: 11,1,2
[   28.918855] RTW: rtw_hal_set_bssid wlan0- hw port -0 BSSID: 30:fc:68:61:5e:a6
[   29.325943] RTW: OnBeacon: beacon keys ready
[   29.326023] RTW: link to new AP
[   29.326049] RTW: start auth
[   29.326095] RTW: issue_auth
[   29.626581] RTW: link_timer_hdl: auth timeout and try again
[   29.626682] RTW: issue_auth
[   29.927582] RTW: link_timer_hdl: auth timeout and try again
[   29.927684] RTW: issue_auth
[   29.934779] RTW: OnAuthClient
[   29.934839] RTW: auth success, start assoc
[   29.934897] RTW: network.SupportedRates[0]=82
[   29.934921] RTW: network.SupportedRates[1]=84
[   29.934942] RTW: network.SupportedRates[2]=8B
[   29.934965] RTW: network.SupportedRates[3]=96
[   29.934987] RTW: network.SupportedRates[4]=0C
[   29.935011] RTW: network.SupportedRates[5]=12
[   29.935033] RTW: network.SupportedRates[6]=18
[   29.935056] RTW: network.SupportedRates[7]=24
[   29.935092] RTW: network.SupportedRates[8]=30
[   29.935114] RTW: network.SupportedRates[9]=48
[   29.935138] RTW: network.SupportedRates[10]=60
[   29.935161] RTW: network.SupportedRates[11]=6C
[   29.935188] RTW: bssrate_len = 12
[   29.935217] RTW: rtw_set_spp_amsdu_mode set spp opt = 3
[   29.948817] RTW: OnAssocRsp
[   29.948910] RTW: report_join_res(7, 0)
[   29.948971] RTW: rtw_joinbss_update_network
[   29.949008] RTW: +rtw_update_ht_cap()
[   29.949072] RTW: rtw_alloc_macid(wlan0) if1, mac_addr:30:fc:68:61:5e:a6 macid:0
[   29.949096] RTW: rtw_joinbss_update_stainfo
[   29.949140] RTW: rtw_get_sta_tx_nss: 1 SS
[   29.949163] RTW: rtw_get_sta_rx_nss: 1 ss
[   29.949190] RTW: STA - MAC_ID:0, Tx - 1 SS, Rx - 1 SS
[   29.949212] RTW: STA - MAC_ID:0, SM_PS 3
[   29.949249] RTW: ht_mcs_set=ff 00 00 00, nss=1, bitmap=000000ff
[   29.949275] RTW: ### Set STA_(0) info ###
[   29.949304] RTW: rtw_check_amsdu_disable spp_opt=0
[   29.949337] RTW: rtw_xmit_queue_set(wlan0): enable queue TX for macid=0
[   29.949378] RTW: rtw_cfg80211_indicate_connect(wlan0)
[   29.949484] RTW: assoc success
[   29.949730] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   29.949869] RTW: rtw_set_rts_bw connect_to_8812=0,enable=1
[   29.949975] RTW: rtw_ndev_notifier_call(wlan0) state:4
[   29.950798] RTW: HW_VAR_BASIC_RATE: 0x15f->0x15f->0x15f
[   29.951164] RTW: WMM(0): 0, a42b
[   29.951267] RTW: WMM(1): 0, a44f
[   29.951337] RTW: WMM(2): 0, 5e4322
[   29.951412] RTW: WMM(3): 0, 2f3222
[   29.951473] RTW: wmm_para_seq(0): 0
[   29.951561] RTW: wmm_para_seq(1): 1
[   29.951586] RTW: wmm_para_seq(2): 2
[   29.951607] RTW: wmm_para_seq(3): 3
[   29.951632] RTW: HTOnAssocRsp
[   29.951881] RTW: ============ STA [30:fc:68:61:5e:a6]  ===================
[   29.951911] RTW: mac_id : 0
[   29.951932] RTW: wireless_mode : 0x0b
[   29.951952] RTW: mimo_type : 0
[   29.951982] RTW: static smps : N
[   29.952043] RTW: bw_mode : 40MHz, ra_bw_mode : 40MHz
[   29.952093] RTW: rate_id : 1
[   29.952127] RTW: rssi : -1 (%), rssi_level : 0
[   29.952179] RTW: is_support_sgi : Y, is_vht_enable : N
[   29.952202] RTW: disable_ra : N, disable_pt : N
[   29.952222] RTW: is_noisy : N
[   29.952243] RTW: txrx_state : 0
[   29.952266] RTW: curr_tx_rate : CCK_1M (L)
[   29.952286] RTW: curr_tx_bw : 20MHz
[   29.952307] RTW: curr_retry_ratio : 0
[   29.952330] RTW: ra_mask : 0x00000000000fffff
[   29.952330]
[   29.952668] RTW: wlan0 wakeup macid=0, ori reg_0x4d4=0x00000000
[   29.952722] RTW: rtw_xmit_queue_clear(wlan0): disable queue TX for macid=0
[   29.953087] RTW: +rtl8723d_download_rsvd_page(wlan0): hw_port=0 mstatus(1)
[   29.953453] RTW: _rtw_hal_set_fw_rsvd_page(wlan0) PageSize: 128, [ NOR ]-RsvdPageNUm: 10
[   29.953627] RTW: LocPsPoll: 4
[   29.953674] RTW: LocNullData: 5
[   29.953698] RTW: LocQosNull: 6
[   29.953725] RTW: _rtw_hal_set_fw_rsvd_page PageNum(7), pktlen(896)
[   29.953929] RTW: _rtw_hal_set_fw_rsvd_page: Set RSVD page location to Fw ,TotalPacketLen(896), TotalPageNum(7)
[   29.953978] RTW: RsvdPageLoc: ProbeRsp=0 PsPoll=4 Null=5 QoSNull=6 BTNull=0
[   29.954177] RTW: wlan0: 1 DL RSVD page success! DLBcnCount:1, poll:1
[   29.955942] RTW: rtw_join_done_chk_ch(wlan0) union:11,1,2
[   29.959249] RTW: =>mlmeext_joinbss_event_callback - End to Connection without 4-way
[   30.267840] RTW: recv eapol packet 1/4
[   30.267908] RTW: Receive unencrypted eapol key
[   30.267965] NOHZ: local_softirq_pending 08
[   30.268174] NOHZ: local_softirq_pending 08
[   30.268386] NOHZ: local_softirq_pending 08
[   30.273293] RTW: send eapol packet 2/4
[   30.273368] RTW: Respond unencrypted eapol key
[   30.273499] RTW: rtl8723d_fill_default_txdesc(wlan0): SP Packet(0x888E) rate=0x0 SeqNum = 1
[   30.293829] RTW: recv eapol packet 3/4
[   30.293891] RTW: Receive unencrypted eapol key
[   30.293948] NOHZ: local_softirq_pending 08
[   30.294155] NOHZ: local_softirq_pending 08
[   30.294368] NOHZ: local_softirq_pending 08
[   30.322416] RTW: send eapol packet 4/4
[   30.322478] RTW: Respond unencrypted eapol key
[   30.322572] RTW: rtl8723d_fill_default_txdesc(wlan0): SP Packet(0x888E) rate=0x0 SeqNum = 2
[   30.322850] RTW: cfg80211_rtw_add_key(wlan0) adding key for 30:fc:68:61:5e:a6
[   30.322884] RTW: cfg80211_rtw_add_key(wlan0) cipher=0xfac04
[   30.322896] RTW: cfg80211_rtw_add_key(wlan0) key_len=16, key_index=0
[   30.322907] RTW: cfg80211_rtw_add_key(wlan0) pairwise=1
[   30.322924] RTW: cfg80211_rtw_add_key(wlan0) seq_len:6, seq:0x0
[   30.323134] RTW: rtw_cfg80211_set_encryption
[   30.323154] RTW: rtw_cfg80211_set_encryption(wlan0) set CCMP PTK idx:0, len:16
[   30.323181] RTW: rtw_cfg80211_set_encryption, ret=0
[   30.323209] RTW: set pairwise key camid:0, addr:30:fc:68:61:5e:a6, kid:0, type:AES
[   30.323388] RTW: cfg80211_rtw_set_default_key(wlan0) key_index=0, unicast=1, multicast=0
[   30.324162] RTW: cfg80211_rtw_add_key(wlan0) cipher=0xfac04
[   30.324197] RTW: cfg80211_rtw_add_key(wlan0) key_len=16, key_index=1
[   30.324207] RTW: cfg80211_rtw_add_key(wlan0) pairwise=0
[   30.324222] RTW: cfg80211_rtw_add_key(wlan0) seq_len:6, seq:0x0
[   30.324232] RTW: rtw_cfg80211_set_encryption
[   30.324248] RTW: rtw_cfg80211_set_encryption(wlan0) set CCMP GTK idx:1, len:16
[   30.324261] RTW: ==> rtw_set_key algorithm(4),keyid(1),key_mask(0)
[   30.324285] RTW: rtw_cfg80211_set_encryption, ret=0
[   30.324302] RTW: set group key camid:1, addr:30:fc:68:61:5e:a6, kid:1, type:AES
[   30.324923] RTW: rtw_ndev_notifier_call(wlan0) state:4
[   30.325206] RTW: cfg80211_rtw_change_station(wlan0) mac:30:fc:68:61:5e:a6
[   30.855863] RTW: Turbo EDCA =0x5ea42b
[   36.168961] NOHZ: local_softirq_pending 08
[   36.867828] RTW: Turbo EDCA =0xa42b
[   38.871837] RTW: Turbo EDCA =0x5ea42b
[   43.543913] NOHZ: local_softirq_pending 08
[   44.883792] RTW: Turbo EDCA =0xa42b
[   46.892062] RTW: Turbo EDCA =0x5ea42b
[   49.172906] NOHZ: local_softirq_pending 08
[   49.173025] NOHZ: local_softirq_pending 08
[   50.895834] RTW: Turbo EDCA =0xa42b
[   52.899775] RTW: Turbo EDCA =0x5ea42b
[   54.903846] RTW: Turbo EDCA =0xa42b
[   56.907821] RTW: Turbo EDCA =0x5ea42b
[   62.930102] RTW: Turbo EDCA =0xa42b
[   64.923837] RTW: Turbo EDCA =0x5ea42b
